Question about Lakewood Heating & Cooling
Does not show power or heat up - Lakewood Heating & Cooling
  • 111 Answers
Check power source,cord, still no, check internal power connections,check safety cutout switch, overtemp switch,check for fuse on curcuit board, replace board, use a multi-meter
Posted on Jan 31, 2010
I have a sunbeam two control mattress heated pad. One side works fine but the other will show a F error when put on preheat..
look for creeses in liquid lines. also check fualty wiring for voltage. switch power to pads if it heats look at power supply
Jan 03, 2018 | Sunbeam Heating & Cooling
I have a AEG Favorit 65011 VI dishwasher which stops in the middle of a programm an shows error ,60 that is not mentioned in the Users Manual. Can you please help me?
Fault in heating phase. Could be:
Heating element, wiring between heating element and power board,
power board (usually relay). Sometimes can help to resoldering (cold solder joint) or replaced relay on power board.
Dado
Mar 10, 2015 | AEG Dishwashers
How do i know if the heating element is broken?
Make sure power is off. With an ohm meter check resistance through the heating element. If the reading shows O.L. on the display the element is bad. If it shows resistance then you might have a power issue. Check voltage at the harness when power is on.. If you are not familiar with working with live electrical circuits do not attempt. Call a certified technician.
Mar 01, 2015 | Dryers
Hello, Dryer won't heat. igniter shows 80 ohms resistance. but there is no power to it. two sensors on exhaust shoot show red wire hot with power through. sensor on intake shows no power. switch by motor...
what is the brand name and model number,if it's a whirlpool or kenmore check the thermal fuse,when you read out a part you have to remove at least one wire.
May 04, 2011 | Dryers
Have RHOSS heat pump showing E01
Different manufacturers use different codes, as I am sure you have figured out. Most of them that I have run into E-01 means the inside and outside units are not communicating. One is without power or there is a broken or loose wire.
Jul 17, 2010 | Heating & Cooling
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Heating & Cooling Logo
245 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
