Question about Dell 8X DVD-ROM Drive for Precision M4300/M2300 Mobile Workstation DVD Drive
Drive disappear. shows yellow exclamation marks
    President:
  • 1,566 Answers
This article might help you in fixing the error code 19. I have tested this one and it worked for me. The error means that the optical driver got corrupted.
Microsoft Windows Vista
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Microsoft Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on Jan 30, 2010
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
Tip
Restoring Missing CD/DVD drives from my computer
The cd/Dvd drive has disappeared from windows explorer and system folder "my computer " A glance in the device manager shows that obviously there is some serious problem .the entries are marked with a yellow exclamation marks .This is also confirmed by opening "properties' in the context menu of the device ,it reports "error code 19"an error has occurred in registry .
This kind of problem can be solved by changing some entry in registry .open registry editor with "start" "run" in run type regedit and click "ok" and go to Hkey_local_machine>system>current control set>control class>{4D36E965-E325-11CE-BFC1-08002BE10318} in the right side of the window,delete both the values"uper filters"and "lower filters".To do that select the successive entries press (del),and confirms the security query that will pop.After restarting your system the drive will be back again.
on Apr 24, 2010 | Computers & Internet
IBM eServer xSeries 236 yellow Exclamation mark
yellow Exclamation mark mins some error check side cover on ibm x236 which light show orange then rpl
Sep 23, 2011 | IBM eServer xSeries 236
Supertalent express ram cache drive no detected by os the light is lit at steady state does does not show activity It does not show in "my computer"
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 24, 2011 | SuperTalent Super Talent Express RAM Cache...
My cd drive writer 640c won't work, I check the device manger and it had a Exclamation sign in yellow by it
HI,
open device manager, right click on cd-dvd driver with yellow ! mark and select uninstall
it would be disappeared.
then open the following Fixit software weblink and run it
http://support.microsoft.com/kb/929461
restart computer, yellow !mark would be gone ..
issue resolved :)
May 26, 2011 | Computers & Internet
I using a kaspersky 2011 antivirus and its showing yellow exclamation mark on kaspersky icon. please help me how to solve this problem
Usually the yellow exclamation mark means you need to update the program's AV definitions.
Just run the update tool within the program, this should get rid of the symbol.
Mar 18, 2011 | Kaspersky Labs Kaspersky Anti-Hacker...
Hpdv9910us cd/dvd does not play
IF you go into my computer and your drive is not showing then i would go into your device manager and see if your cd/dvd drive shows a exclamation mark if it does then you have to go into your registry and delete upper and lower filters
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
if you show no exclamation mark in your devicemanager then you myst call HP for repair
Mar 01, 2011 | HP Pavilion DV9910US Notebook
Dvd driver shows yellow excclamation mark error code 41computer novice any simple suggestions would be appreciated
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
7) Reboot
your computer
Regards,
Pp
Dec 02, 2009 | Computers & Internet
Lost the sound on my laptop, amilo d 7830
You most likely need to reinstall the sound driver for your laptop.Right click on the My Computer Icon and then left click Properties.Go to Hardware, the Device Manager.If you have a yellow exclamation mark next to Sound, you need to download and install the driver.Go to the manufactuters web site for the driver.
Oct 24, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Packard bell CD rom
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Jul 01, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Dell 8X DVD-ROM Drive for  Precision M4300/M2300 Mobile Workstation  DVD Drive Logo
Alun Cox
