Question about Samsung SGH-A877 Impression Cell Phone
My sons screen froze up and is bright green ... took battery out held down power key then replace battery ... went from loading a blue screen back to bright green - Samsung Impression NEW phone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
If it's a new phone, take it to the place that you purchased from and have them check it out. Make sure you take your box, charger, and paperwork and receipts with you. Good Luck.
Posted on Jan 31, 2010
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
My laptop froze up:
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Mar 10, 2010 | HP Computers & Internet
Gateway 450ROG Laptop was downloading a video when the screen slowly went all white. I had to power off. I waited a while reloaded the battery and powered up. I got the windows didn't power down right....
You must go through the safe mode and uninstall your graphics driver and install another one, may be you will find more compatible driver with your graphics card and your windows copy on gateway website.
Jan 31, 2010 | Gateway 450ROG Notebook
Won't load the operating system
try booting into safe mode, and uninstall the program
to do this: right before the windows xp logo shows, rapidly hit F8 on the keyboard, you should get a screen that shows the advanced startup options, after you see this, use the arrow keys to select 'Safe Mode' and hit enter, the computer should boot successfully and you can uninstall the program.
NOTE: if you hit F8 too late, perform a cold-reboot (hold down the power button until the computer is off and then turn back on) and try again
Dec 25, 2009 | Dell Inspiron 2650 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
I737 digital lens will not move
There is nothing you can do. A tech will need to diagnose and repair it. Sell it at an online auction house to recover some money.
Jan 09, 2009 | Cameras
Phone shut off
Have you tried removing and replacing the battery pack? Or removing the battery and plugging it in to the charger? If neither works, try holding down the Power button to get it to start back up.
Jan 06, 2009 | T-Mobile Wing™ Smartphone
Psp turns on but there is a blank screen
it probably froze try and remove battery. if that dont work turn it on and wait a second then hold the power switch in the off position but do not let go until it turns off that should completey restart it.
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Frozen
let the battery run out then restart/reboot. if this does not work, you may just want to get another one because the problem could be your motherboard. connie
Jun 25, 2007 | SanDisk Sansa e250 MP3 Player
Samsung SGH-A877 Impression Cell Phone Logo
1,143 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
