Question about Maytag MTB1504A Top Freezer Refrigerator
My Maytag Performa ice maker is not making ice...any suggestions?
My dispence system on the outside of the freezer is not working. ice ,and water not coming out, but the frig is making ice.
Posted on Feb 06, 2011
I have a Maytag Performa PTB2153FR ice maker that I believe was over filling-now it's not filling at all. I cleared some ice out of the water line but it's still not working. Not sure if I replace the...
if you are doing this stuff and have questions your problem is you are doing your own work and obviously have no idea what you are doing, and you should stop it and call a professional.
Jan 01, 2015 | Maytag Refrigerators
Maytag MFI2067AES Icemaker is frozen and cannot be used. It is now a solid block of ice. Please don't suggest using a hairdryer. It does it all the time. Also a hairdryer is useless without dismantling the...
is the fill tube clog? the ice maker is not going to harvest mode. Take the ice maker cover off and put a jumper on T and H hole the dial will turn and wait until you hear the click remove the jumper. make sure you have gloves on. Do this at your own risk, if you are not sure call a servicer. If the dial won't turn you have a bad ice maker (if you have a 115 volts to the ice maker).
Nov 22, 2017 | Maytag MFI2067AES Stainless Steel Bottom...
I have a Maytag Performa side by side refrigerator/freezer. It is no longer making ice.
Several things can cause this...
First, is there snowy frosty ice built up on the back wall in the freezer?
Yes= hire a professional!
No= Replace Ice maker and water valve!
Thanks and let me know if that helps,
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Aug 26, 2011 | Maytag MTB1504A Top Freezer Refrigerator
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
I have a performa pds262lhe7 refrigerator. the water runs slowly and the ice maker hardly works. do i need a new water filter?
Your filter is clogged. Replace the filter in the refridge side, it is located on the top right hand side.
Mark
Jul 05, 2009 | Maytag MSD2756G Side by Side Refrigerator
We have a maytag performa side by side fridge model number psb2151gr the ice maker is not hooked up but it creates ice and collects in the bottom of the freezer and runs out on the floor how do i fix this
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Psd262lhez performa side by side
I got one of these in my shop. I am tech, call me for info. steve 320.963.3580 MN
Sep 28, 2008 | Maytag MZD2766GES Side by Side...
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Maytag MTB1504A Top Freezer Refrigerator Logo
796 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
