TV won't turn on. Relay clicks 4 times in stead of 2. Like it keeps trying yet to no avail. RCA 32" CRT March 2000
    Novelist:
    Champion:
  • 211 Answers
You may have a bad B+ problem. This is normally caused from a bad Horizontal Output Transistor or a capacitor feeding the B+ circuit. If you can do your own repair, check the main components/parts feeding the high voltage section. As always, check for cold solder joints ( bad/broken solder from the printed circuit board ) and solder them if you see anything that looks different or loose. Remember ALWAY( PRE-CAUTION, UNPLUG THE SET FROM THE WALL BEFORE SERVICING AND NEVER GET CLOSE TO THE LARGE RED WIRE FROM THE HIGH VOLTAGE TRANSFORMER ( IT CAN CHARGE UP TO 30,000 VOLTS ) Good Luck on your problem and I hope this has helped in some manner.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
My RCA F32650 32" TV keeps turning on and off. I
hi there! i hope this will help u find the solutiuons:
1. replace the power transistor at the horizontal section of your tv by desoldering . and buy with the same value, the store assistant in your area will do help you replacing the defective part of your tv. Thank You.
Feb 06, 2011 | RCA F32650 32" TV
TV won't turn on
no; it means the points on the power relay are burned; unsolder RL-1 and, replace it.
It is a small 1/2"x 1/2" plastic cube near the power cord.
Jan 26, 2010 | RCA F32650 32" TV
My RCA tv is coming on and off by itself and I can not control it with the remote The model # is F32645 - SN is 012431337 - mfg March 2000
these tv's are common to bad solder joints. and there are many. if you do go about resoldering the unit. make sure you use a silver solder alloy 2% or it will not mix well with the junk "elastic" solder the mfg. used
Dec 28, 2009 | RCA F32645 32" TV
My sournd sound turns on then turns off can any one help
so is this sound on the tv or a sound system
May 03, 2009 | RCA F32649 32" TV
Connect laptop to RCA - F25305
What kind of computer do you have? There wuold have to be a video out or SVHS plug out from your computer. And a video or SVHS input to your TV. If both are physically available then there should be a computer configuration so your laptop can output to your TV.
Sep 17, 2008 | RCA F25305 25" TV
RCA F32649 32" guide plus TV
you need to check the fuse ,maybe it's busted.
Sep 04, 2008 | RCA F32649 32" TV
RCA 32v430t
peanut36,
Bad HV transformer = RCA part # 271996.......................T.
fermin,
Please log on to Toshiba rear projection Television>>>>>>>>>
turbo5150,
The exact same problem with ? = Make & Model,please....T.
Dec 17, 2007 | RCA F32650 32" TV
Bad RCA 32 Tube TV
Bad IHVT ( HV transformer ) part # 257805 or ASTI 2078
......................................................T.
Dec 11, 2007 | RCA F32650 32" TV
Green Screen
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
Sep 12, 2007 | Insignia IS 20" TV040919 TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
