Question about Homelite Garden
Starts dificult; runs for 30 sec then shuts off abruptly
  • 714 Answers
RECOMENDATIONS:
-Drain all fuel from the Saws fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the Saws fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running.
Hope this Tip Helps.
R/
David
Posted on Jan 31, 2010
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
Desktop shuts down abruptly but will restart without problems.
best start looking into a cooling fan problem .
Mar 16, 2015 | Computers & Internet
LT133 lawn tractor starts then stops. no spark,has gas filter ok,cleaned safety cutoff switch under seat. mower starts up,runs for 20 sec then stops.
Does the engine start up every time right when it shuts off, or will the engine not start until it's cooled off? And when the engine is running for the 20 seconds........ does it give any indication that it is going to stall, or does it abruptly shuts off with no indication of stalling? Let me know and I'll try to get back to you as soon as I can.
Oct 07, 2013 | Garden
I have a McCulloch Model FR 2.3 18 in. chainsaw that will fire up and run for approx 30 secs. and then shut off. If I pump the primer bulb twice, it will fire up again for approx 30 secs. I'm ve
This is oviously fuel starvation, the first thing to do before speding too much time on it is to replace the fuel filter in the fuel tank, hook the hose out with a piece of bent wire, pull the filter off and replace, as a quick test pull the filter off, let the fuel hose go back into the tank, make sure the tank is full, now try. Do not leave like this you must fit a new filter.
Mar 30, 2013 | Garden
My computer shuts down abruptly even before loading windows.all the funs are running normally thus i overule the problem of overheating.
you could run a memory test "mamtest86", you could start removing unnecesarry pherephials and cards (who needs a telephone momem anymore?) and disabling devices in your bios, and you could test your power supply.
May 21, 2010 | Asrock P4I45GV R5 Motherboard
Maytag dryer starts for 30 sec.+thenshuts off with
sounds like the blower is not cooling the heater coil fast enough this will cause it to shut down to prevent fire
Jun 06, 2009 | Dryers
The power light keeps flashing orange
I had my Optiplex GX520 at work shut down abruptly every time I turned it on it in the morning. This would always happen within the first 30 minutes. I would then get the flashing amber light. After starting the PC again, it would stay on all day (over 8 hours) without shutting down again. I found that the power supply was over-heating.
Two things need to be done. First, in order to get the amber light to stop flashing, un-plug the computer from the wall for 30 seconds then plug it back in. OR hold down the power button for 10 seconds or so. The light should stop flashing. Then press the power button again and the PC should start.
But why did it abruptly shut down in the first place? The power supply has a fan-speed-control circuit in it to keep it running slow and quiet when the power supply is cool. It gives the power supply lower voltage when the power supply is cold and higher voltage as the power supply gets warmer. This circuit either is not working correctly or the fan getting sticky over the years and needing more voltage to get it moving when it is cold. I found that the fan was not starting at all and causing the power supply to over-heat.
To keep the fan moving at full speed, I cut the wire to it and wired it to the +12v output directly. Not the fan goes at full speed all the time. And yes, it is nosier. But at work it doesn’t matter.
The best solution would be to just get another power supply from Dell if possible. Or buy a +12v, 70mm fan from Digi-Key and replace the original.
Jun 27, 2008 | Computers & Internet
Walkin cooler
Most Likely Low on Freon. Low Pressure switch shuts That Compressor Off.
Dec 29, 2007 | Refrigerators
Garden Logo
101 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
