Question about Linksys Wireless-G WRT54G Router
How do i set up a secure network? - Linksys Wireless-G WRT54G Router
  • Anonymous Feb 19, 2008
    i have no security, when i play xbox live(wireless). i get disconnected every 10 minutes or so
  • 33 Answers
PC magazine has a good article on wireless security...
http://www.pcmag.com/article2/0,4149,1277020,00.asp
A strong WPA password along with a strong admin password for the router setup are a must.
Posted on Feb 18, 2008
    Scholar:
  • 110 Answers
Hiya! I assume you mean via the wireless settings. I could type out a long step-by-step, but this page is probably more helpful. Note that step 8 is optional and not even I lock it down that far. Good luck, and feel free to respond with any questions while working through it.
http://www.howtodothings.com/computers-internet/how-to-protect-a-linksys-wrt54g-router-using-wap-and-wep
Tip
Setting up your Wireless Printer: How to check your Network Settings
To check your network settings from your computer
  • for Vista click on start then Connect To, then right click on your network and click Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows 7 Click on the Network/Wireless icon on the task tray click on Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows XP click Start, then Connect To then Network Connections, right click on Wireless Network Connections click on Properties then write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
on Mar 28, 2011 | Office Equipment & Supplies
Tip
Wireless security issue. How to secure the network ?
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Click here for step by step instructions
Onceyou open the set up page of the router , you will find the place tochange the wireless settings of the router. In case of Linksys wirelessrouter , you will see the Wireless Tab at the top.
SSID :It is the name of the wireless network. This name will be shown on yourwireless computer or the wireless device so that you can identify yourown wireless network. All the routers come with their factory defaultsettings. For example , the Linksys router will come with the Linksysnetwork name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP.This security type is supported by all the operating system. Whenchange the security mode to WEP, you will find the Network key box totype the network key. Do not type anything in the Passphrase box. Typeyour network key in the Key 1 Box. If you set the encryption to 65bits, your network key will be 10 digit hexadecimal number. that meansyou can use the combination of 0,1,2,3,4,5,6,7,8,9 and lettersa,b,c,d,e,f only. remember it should be exactly 10.
If you set theEncryption to 128 bit, your network key will be the combination of 26digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Openthe set up interface of the router. Change the wireless security modeto WPA personal. You will find the passphrase box. in this box you cantype any password for your wireless network. The password should be thecombination of number and letters and it should be 8 or more than 8characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Openthe set up interface of the router. Change the wireless security modeto WPA personal. You will find the passphrase box.In this box you cantype any password for your wireless network. The password should be thecombination of number and letters and it should be 8 or more than 8characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network .
on Dec 04, 2009 | Computers & Internet
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Where is the network security key
The network security key is set by the user when the home network is setup. It prevents people from stealing your wireless signal. If you have forgot it, or didn't set it up but it still is asking for one, you can unplug and hit the reset button on your router and delete the home network you have on your main computer. From there, just run the network setup wizard from the main pc and set your network security key to something you can remember as well as write it down. Then you should be set to add any other pc to your home network as long as when you try to connect, you put the correct key in.
Sep 28, 2012 | Belkin (F5D7231-4) Wireless Router
Psp wont connect to wireless network
The problem lies within the type of security used for the wireless network.
The PSP cannot connect to some networks that use different types of security settings.
1. Check Network security settings
2. Make sure they are compatible with PSP wireless settings
3. Identify password for wireless network
4. Connect to wireless network from PSP
Mar 14, 2011 | Sony Video Game Consoles & Games
Securing wireless network
By setting up WPA2 encryption you are securing your wireless network from unauthorized access.
For details on how to further secure your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 09, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Can't get the Linksys Router's list of Network Security Settings
The router has a built-in web-server.
So, just connect your web-browser to that web-server,
select the correct page, and click PRINT.
Jan 01, 2010 | Linksys WRT160N Wireless Router
Need to change password from previously changed password
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
WPA2
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Linksys Wireless-G WRT54G Router Logo
130 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
