Question about Cameras
Lense won't open or close
Lense is stuck won't open or close
  • 685 Answers
It is time to send it in for service if it is an expensive camera ($200 or more retail price) or throw it away if it is inexpensive. A repair for that may run $100, espcially if it was bumbed ot dropped and ther is mechanical damage. If it is under the warranty then definitely send it off.
Posted on Jan 30, 2010
5 Suggested Answers
VinayT
  • 1884 Answers
SOURCE: kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Posted on Aug 11, 2009
  • 7 Answers
SOURCE: the lense is stuck open. it clicks and attempts
If you got some gunge in the mechanism it might have seized up. You could try taking a shop vac or vacuum cleaner nozzle and sucking at the lens while actuating it. That worked (for a while) and a camera that we had. If that doesn't work, try canned compressed air.
The next step is getting the lens assembly replaced at a repair shop. If you are foolish enough (like me) to try replacing the lens assembly yourself, assure that you either have good instructions with the replacement part, or assure that you are able to get it apart before buying a new lens assembly
Posted on Dec 01, 2009
jonags3
  • 83 Answers
SOURCE: the camera lense is stuck open and not will close
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
Posted on Jul 19, 2010
Obertelli
  • 3006 Answers
SOURCE: have to open and close
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Jun 20, 2011
My samsung S1050 lense will not open or close, it is stuck half way.
forcing it closed usually ends badly...stripped or sheered gears.TRY putting pressure on the lense durring power up...if it feels like it will move let it go....next using a small jewelers screw driver try to pull the lense open ...may take a bit of playing...be patient!
Nov 11, 2014 | Samsung S1050 Digital Camera
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
Won't stay on
Sound like a stuck lens problem; check here about fixing-lens-error-on-digital-camera.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 03, 2012 | Fuji FinePix A330 Digital Camera
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
The camera lense is stuck open and not will close
jonags3
Jul 19, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 15, 2010 | Canon PowerShot S2 IS Digital Camera
I have a canon powershot sx100 IS the lens is
Here is a site that discusses things you can try to fix this for free. They do a much better job than I could, and they let you know the risks and steps to take, in order. Try this first, you might get lucky- they say 50% of stuck lenses or lens errors can be fixed.
Don't worry, this is a huge problem with extendable lenses, due to their construction with small, plastic gears that are easy to break with a bump or fall, or obstruction while extending.
Apr 18, 2010 | Canon PowerShot SX100 IS Digital Camera
Kodak V1253 lense won't close
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Cameras Logo
594 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
