Question about HP PSC 1350 All-In-One Thermal Printer
No power on the printer
No power is available upon opening the printer. had it called for service maintenance but to no avail since service center here in the phils accepts trade in only. meaning you pay in exchange for a new one of the same model. had already cheked the power supply cord and nothings wrong. pls help
  • mpmgcd Mar 23, 2009
    My printer has function correctly for the past 4 years, suddently i can`t turn it on. The cables and the box are working ok. Thank for your help.
    Novelist:
  • 57 Answers
I understand that you are unable to turn on the printer.
Please follow the instructions from the article to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&docname=bpu02181
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&docname=buu02610
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&docname=bpa00586
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Please follow the instructions from the above web documents to resolve the issue.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Posted on Feb 18, 2008
I cannot open HP director
Go online to HP.com and see if HP Solution Center is available as a software upgrade for your printer.
Director was discontinued ages ago and most printers have the solution center software available from their website.
May 30, 2011 | HP PSC 1315 All-In-One InkJet Printer
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
We just had a power outage. Upon restoring power, the copier came up with a call service c-6000 error. Is there a fuse somewhere?
C-6000 Indicates a bad fuser. Could be just a poor connection in the fuser, thermister, thermostat. etc. Regardless you need an authorized service center.
Mar 22, 2011 | Kyocera Copystar 181 Copier
It keeps saying replace maintence kit. I don't even know what that is. Can you please help
Maintenance Kit - Contains: Fuser, Transfer Roller, Paper Feed Rollers & Separation Pads , etc
look at below picture, kit available with instruction manual etc its easy to replace. or you can give it to the service center.
best of luck
Jan 26, 2011 | Ricoh Aficio AP610N Laser Printer
How to clean printer head esp 5 kodak printer all in one
I have replaced my Kodak ESP Printer head twice in two years. I'm with who ever said Kodak refuses top acknowledge the problem. The customer service told me that all printers have problems and they get very few complaints. I dont think I'm buying anymore Kodak products.
Sep 27, 2010 | Kodak ESP 5 Printer
Have XDL33 Copier. Has been out of service for a while because when turn it on get u42 error code. Had this code several times before while it was under maintenance contract and only took tech a few...
Hello sir; Yes, you can do it by youself,just follow my instruction;
Open front door , hold 0 while you turn on power then enter 50 press start key, enter 20 press start key again, then close door turn power off and back on.
Aug 20, 2009 | Xerox XDL-33D Black and White Copier
Kodak ESP-5 AiO says "0%" ink even after I install new cartridges
Let's clean and align.
Make sure that there are 5 - 10 sheets of plain paper loaded in the paper tray.
2 Press menu to display the main menu.
3 Press down arrow until Maintenance is selected.
4 As needed, press down arrow until the desired option is selected.
5 Press OK.
6 Follow the prompts in the display screen to initiate or cancel the task.
These available maintenance options are shown below:
Check Ink Levels
Nozzle Check
Printhead Alignment
Clean Printhead
Print Demo Sheet
Print Test Page
From windows, : Open the Home Center Help panel by clicking Help on the Home Center window, as needed. Click Maintenance, and then click
Nozzle Check or Printhead Alignment.
Macintosh: Open the Home Center window and click Maintenance, and then click Nozzle Correction or Printhead Alignment.
Should be good now.
Regards
Richard.
Apr 24, 2009 | Kodak ESP 5 Printer
Phaser 8400 error code 37,016,43:7052
From the service manual:
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
I have the full service manual available should you need it. Thanks and please take a moment to rate this solution as fixya.
Feb 22, 2009 | Xerox Phaser 8400 Laser Printer
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
Please help me asap...
You may open this link and choose the OS that you are working on. You have the drivers and the software available which you can download.
http://tinyurl.com/7er5u
Hope this resolves the issue you are facing.
Sammy
Nov 28, 2007 | Office Equipment & Supplies
HP PSC 1350 All-In-One Thermal Printer Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
