Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Control board say not availible when any button is pressed, only shows av1 picture and picture is scrambled, toshiba 42h83 modle rear projection tv
  • danielcurvin Jan 31, 2010
    yes i am and no i dont have a shop manual. ill check that out thanks for the info
  • 438 Answers
This may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Posted on Jan 31, 2010
  • Fal Mueller
    Fal Mueller Jan 31, 2010
    yes get a manual, when attempting this repair good luck, let me know how you did
My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Apr 27, 2012 | Toshiba 42H83 42" Rear Projection...
WE HAVE A 50H82 PROJECTION TV. THE PICTURE QUALITY IS TERRIBLE (WOBBILY), ALMOST LIKE WHEN YOU NEEDED TO ADJUST THE TRACKING ON A VHS PLAYER. CAN YOU DIAGNOSE THE PROBLEM FROM THIS DESCRIPTION?
Most likely the Hyper board is causing the scrambled picture. Very common problem but the boards are no longer available you may try ebay or something for a used one.
Jul 23, 2011 | Toshiba 50H82 50" Rear Projection...
My Toshiba 42H83 has a scrambled screen for about 5 minutes when it is turned on, if it has been off for a while. Once it warms up, it works fine. I have replaced the satellite receiver but this did not...
ok, you are talking about lines in the picture, it started where it would clear up after a few minutes but now it will slowly take longer?
I know what is wrong.
SD TECH
Oct 22, 2010 | Toshiba 42H83 42" Rear Projection...
Have a toshiba 42H83 how do I get into service mode? think it is menu menu(hold) and push what at the same time
ENTERING TO SERVICE MODE
1) Press MUTE button twice
on Remote Control.
2) Press MUTE button
again to keep pressing.
3) While pressing the MUTE button,
press MENU button on TV set.
May 16, 2010 | Toshiba 57H81 57" Rear Projection...
Wavy line or scrambled picture when l turn the tv on it takes 30mins for the picture to come in clear
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Skyassoc
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
My toshiba 42h83 has a shaking picture with a 2 to 3 " green stripe at the top of the screen. How can I fix this?? thank's Karl
Check all wires cables go to the tv,shakes,jiggles might,see the prob.than change the wires cables.Not wires cables,than ur main video board is the prob.must change.
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
