Question about Refrigerators
Not cooling or freezing. compressor and fan running
    President:
  • 1,515 Answers
Hi, you say compressor and fan are running, you have 2 fans, a condenser fan motor in the back behind the panel at the bottom, and the evaporator fan in the freezer. When you check the condenser fan in back by the compressor, check the front of the coil to make sure it is clean as the fan pulls air through the coil to keep internal pressures down. You may have a sheet of dust on it. Check these things and get back to me. Keep me posted.
Sincerely,
Shastalaker7
Posted on Jan 30, 2010
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
I have power to the unit but will not cool or freeze. Cooling unit is hot
Check to see if the condenser fan at the back underneath near the compressor is running.It should be running any time the compressor is. See if you have power to the fan and if you do and it's not running then replace the fan.
Aug 24, 2011 | Dometic RM2652 Refrigerator
Its running cool, But not cold, and will not freeze, the fan is running, the compressor is very hot,, I thought it might be that defrost bar, in the evaporator was not working, which would mean its...
Not cooling compressor running... Verify fan by compressor is running. Verify doors are sealing.
Are Coils are hot in the back by compressor? Clean exterior coils.
Jul 19, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerators is not blowing cool enough air to freeze or cool each side respectively.
I assume the compressor is running since you indicate you have some cool air.
Check to make sure the compressor fan is running. This fan should be near the compressor. Its purpose is to pull room air across the coils and remove the heat from them. If this fan does not operate properly, the refrigerant will not be cycled properly. If the fan is not turning, you will need to replace the fan motor.
Oct 17, 2009 | Refrigerators
My u line icemaker was freezing water but my iemaker was not working. I just installed a used icemaker, now the compressor and fan work, but no cool. compresor conections dont show leaks, compressor gets...
If the compressor and fan are both running and no cool then you have a sealed system issue. If you just replaced the icemaker assembly and it freezes but doesnt dump then you might have the wrong icemaker or a bad thermostat.
Jul 15, 2009 | U-Line Icemaker
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
