Screen flickers caving in from sides and then shuts down
You may have bad convergence chips in the set. I have worked on some with similar problems and replacing the convergence chips was the solution. Good luck and I hope this has helped.
Ed
NC Electronic
Mills, Wyoming
Unless you have a older set ( 6 years old or older in most cases ) there are only 2 convergence chips. The number normally starts STK. ( ie: STK 392-020 ) . If you have an older set, you may have 3 chips or maybe even just one controlling all three colors. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
I just sent a response on another of your posts. If I can help more, call me at my home 307-266-4675. I would be happy to help in any manner possible.
Ed
NC Electronic
Mills, Wyoming
Call right now if you'de like...
307-234-6177.
Ed
Are there three chips for red, blue & green?
I had convergence chips replaced, and the repairman resodered suspect connections. TV worked for a couple of months with perfect resolution and then sudently went back to the same flickering and shutting down. It has been in a local toshiba dealer repair shop for two weeks and they say they cant find the problem. They said they replaced a couple of bad capacitors but didn't help. They suggest I buy a new TV?
What would be a good time to call you?
