Question about Maytag PYE2300AY Electric Dryer
Model #PYE2300AYW Dryer. Changed therm fuse. Died in 5 loads. Changed therm fuse/Hi limit. Died in one load. This is a fairly simple machine. Could op thermostat be taking all these out? Tnx
  • nbvwells Mar 18, 2010
    Vent was ducted under a large back porch. Ends of the porch were skirted to prevent unwanted four legged intruders. I removed one end of the skirting and have had no more trouble, apparantly it was sealed tight enough to restrict dryer vent.
  • 4 Answers
Your lint trap and/or ducting could be blocked. This will cause the machine to overheat and the thermal fuse shuts it off before it burns your house down.
Posted on Jan 31, 2010
Electrolux model eied55hiw no power or display lighting, or dryer light when door is open. Therm Limit ohms good. Any ideas from here?
check your terminal block for short if it checks ok then i would start at the control , check incoming voltage and voltage to your display , use the tech sheet to follow wires .
Feb 17, 2013 | Electrolux Eied55hiw Eied55hiw Front Load...
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Dryer does not start
Check the fuse on the blower housing.
To get to the heating element on most of these dryers you remove the back dust cover: whirlpool%20dryer.jpg 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
Sep 13, 2009 | Dryers
Dryer ran fine. Next load it would not start. It is a 220V, 5 cycle-3 temperature unit. Model # LER5636EQ3 TYPE: 178-00
Check your door switch to make sure its ok. Whirlpool has a fuse on the back of the machine inside. Fuse will be white in color. If that is open, check for a clogged vent or ck your hi-limit thermostat. If everything else is ok you have a bad timer.
Sep 10, 2009 | Dryers
Have a kenmore gas dryer, model # 11072802101, that will not heat at all. have already changed the thermal fuse with no change.
The 'operating' thermostat and the high temp limit thermostat could be bad. There is also a contact on the motor in the element circuit. The two therm. mentioned should read '0' ohms with a meter. (with machine unplugged.)
Jul 09, 2009 | Dryers
Kenmore dryer just stopped working??
replaced thermal fuse and working like new
Apr 08, 2008 | Kenmore 62602 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
265 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
