WHAT TYPE OF HHD DRIVE 2.5'' OR 3.5'' IS ON A ESYSTEM1201?
    Scholar:
  • 94 Answers
2.5 inch drive specs states 120 gb capacity going to assume sata. Here is a link on what I could find for you. From computer manager/disk manager right click on the drive letter and select properties, it will display the drive type, make and details.
http://www.reevoo.com/p/ei-systems-1201-t23701g
Posted on Jan 30, 2010
Kingwin ez-dock 2 dosen't support 3 tb hhd
I bought a dual drive SATA enclosure and found out after purchase that only 1 drive could be active at any one time. I had to manually switch dives on and off. The reason was that the enclosure did not have a SATA drive multiplexer in it and neither did my laptop's Esata connector. A similar issue with USB.
Mar 06, 2014 | Kingwin EZD-2536U3 - Ez-dock2 2.5in Or...
I have a 500GB Maxtor hard drive and it is emitting a beep when plugged in and nto being recognised by the computer
a hhd have 5 years of warranty so u can replace the hhd and get new hhd , if u need some files then tell them to restore the files
Dec 05, 2011 | Maxtor Hard Drive
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device displays the standard green light. I tried connecting the device to...
Most of these problems are associated with an I.C. on the board that governs the HHD. Unfortunately, the chip gets pitted (overheats) on the GaAs and is ruined. The green light (LED) on the HHD will turn on as it is getting power but the main chip that controls the HHD no longer works thus rendering the HHD inoperative.
Bottom line, get a new external drive. Should you get the same model or something similar to what type of electronic hardware you have, you can remove the new HHD and put your old HHD in its place and you will see that all of your data is still intact.
Apr 12, 2011 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Hi IMy seagate barracuda 500gb internal hhd has sector 0 bad.No way with many program to resolve it.I can' format,always say me that there is a bad sector.I used seagate tools,hhd disk repair and othen...
Since the HDD has rejected easy repair by the most appropriate tools, I recommend you recover the data and replace the drive. I've been through this many times for clients.
You did all the right things.
Best Wishes
Aug 04, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to replace operating system new hard drive netvista 2292 22u
jsut pop in the recovery cd and follow the direction.
make sur eyou remove the old HHD.
you can copy all of the files from the old HHD after the new HHD is in working order.
Mar 24, 2009 | Computers & Internet
Adding old hard drive to new pc!
the seagate HHD (secondary drive) need to be on the same cable as the primary HHD. unless you haev SATA. then it is need to be connected to the second SATA connector on the mother board.
go to BIOS setup and make sure the BIOS know there are 2 HHD.
you should be good to go.
Mar 09, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
Error Message???
sound like the hhd is going .
backup all your files to some external hhd or to another computer.
use the Window Xp Cd to reformat eh hhd and reinstall Xp. if the format encounter hhd problem it will stop. in that case, you need to buy a new hhd and replace it. if not the format will go throught, do that twice and reinstall XP.
Jan 14, 2009 | Acer Aspire 5050-3242 Notebook
Duel boot system first xp then vista
Wow....
First I would check the BIOS settings. Make sure that the slave and master jumpers are correct on the drives.
Wouldn't it be easier to make one drive Windows XP on one drive while running Vista on the other?
It would make things easier to troubleshoot.
Jun 12, 2008 | Computers & Internet
Toshiba Satellite A65-S126 Notebook will not boot
Locating the HHD in Toshiba will be the most difficult. They have put them in several different places in the machine over the years. First try any access panels on the machine (look for a small rectangle shaped panel aprox. 1x3, probably on the side), then check under the keyboard, on a couple of models they put them under the touch pad. It should be in a HHD caddy, that will slide out. The caddy will have at least one screw holding it and there will be two or four screws holding the HHD in the caddy. Also check to see if there is a connector on the end of the HHD, you'll need that. Once you've found it, put the new HHD back in the same as the old one and you there.
Jun 11, 2008 | Computers & Internet
Samsung SHR-1040 O/S and Video format/file
the only way to do this is to directly back up the video to your pc from the unit. mj
Apr 10, 2008 | Samsung 4 Channel Dvr
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
