Question about Dishwashers
Why do dishwashers have SO much longer run times today than those of the past? Our new Kenmore ''Ultr-Wash'' has extremely long run-times. How can that possibly be a good thing in terms of saving energy?
  • 10,865 Answers
The latest models all pride themselves in doing a perfect job, almost silently, using much less water than the older models [thus the energy savings] as the most costly part of a dishwasher wash used to be the cost of the hot water. Your dishwasher only uses about 2 KwH of electricity compared to ten year old models that use 16.
Posted on Jan 30, 2010
My 17352 Kenmore dishwasher runs for an hour or more. Can this be adjusted?
There are wash, rinse, and dry cycles that all take time. Cycle settings allow you to vary this. For example, potscrubber mode will take longer than normal wash. You can opt for no heat drying to shorten the cycle, but then the dishes will be wet and can have possible spotting. Experiment with the controls and find the settings that give you the results you want in the least amount of time. But just FYI, an hour isn't that long for a dishwasher to cycle - many run longer than that.
Nov 03, 2016 | Kenmore Dishwashers
The dishwasher continues on the wash cycle for hours, even when I choose the "light" wash cycle
Hello, Thank You for using FixYa. I will be helping you today.Normal cycles on new dishwashers is an average of two hours and opening the door makes it longer.Also if the water temp coming into the unit is not hot enough it takes even longer because now it has to heat the water.Yes new dishwashers can take a very long time to run a cycle.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool Dishwashers
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
Kenmore Quietguard 3 has mold and is dirty inside
G'day, I have a Miele Dishwasher and I have only had one small problem with it in the 12 years I have own it. That was due to moving house, a bit of fluff had moved and was blocking an outlet. once cleaned with a brush it now works like new again. Best dishwasher on the market, made to last 20 years.
Nov 25, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwasher
I found a plastic cone shapped part in the bottom and can not figure out where it goes. thanks
Oct 08, 2007 | Kenmore 15529 Built-in Dishwasher
Kenmore
Make sure you run water in your sink until it is hot before you start the dishwasher. On the newer dishwashers they will fill and drain until the water is hot enough so it takes longer if it starts with cold water. Normal time for a basic wash could take about 45 min.
Oct 07, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
159 people viewed this question
Top Dishwashers Experts
Owen Barnes
