Question about Tomtom GO 720 GPS Receiver
My tomtom screen is on but blank and won't turn off
Blank screen on gps tom tom one xl when turn on it shows an icon of a screen with an x on top
contact TomTom support on this, i believe it indicates the touch screen has failed.
Oct 01, 2009 | Tomtom One XL GPS Receiver
Blinking white blank display after turning on
Try resetting your tomtom by inserting a paper clip through the reset hole found underneath. One quick press is all thats needed. Charge the tomtom first now and then switch on after its had a good charge.
If this doesnt work , please reply again and i'll try and help further.
Good luck
Nov 08, 2008 | Tomtom ONE GPS Receiver
Blank!
a lot of heat will cause your screen to go blank
Dec 28, 2007 | Tomtom One Europe v2 GPS Receiver
Screen display
I guess you have the same problem I did.... I have a TomTom One 3rd Ed., and after updating it through TomTom Home, every time I turned it on, I got a blank white screen. I would have to reset it every time before I could get it to work right. If this is the same problem...go here to download the fix.
http://www.tomtom.com/support/index.php?FID=8578&Lid=4
Dec 27, 2007 | Tomtom ONE GPS Receiver
Blank screen
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
If its NEW take it back!
or
contact tomtom about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 16, 2007 | Tomtom ONE GPS Receiver
Blank Screen
If it is under warranty return it asap or report the problem...
http://www.tomtom.com/support/index.php?Lid=1
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
Download the latest updates from tomtom.
Screen stays lit and is blank
Try a reset. It worked for me with the same problem.
Aug 15, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
79 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
