Question about Brother MFC 7420 All-In-One Laser Printer
Line down page on copies
I have a black line going down the page when I copy (I don't have the problem when I print from a file.) I've just replaced the drum, which helped a bit, but not much. I cleaned the corona wire, and the laser scanner window, and the inside top of the machine. Is there anything else that can be done?
Perhaps I'm not cleaning the laser scanner window correctly. What cleaner should I use? I just used one of those magnetic-type duscloths.
Thank you!
Joanne in Manhattan
  • 11 Answers
What kind of line. Is it solid and think with well defined edges or is it a small thin and dotted? If it is solid with strait crisp edges you will need a new scanner. If it is just a small somewhat dotted you might just have a little something on the scanner glass. Clean it with regular rubbing alcohol and a cotton cloth like an old t-shirt. Don't use swabs or tissue because they can leave lint behind and just give you more lines.
Posted on Feb 18, 2008
I have a minolta ep2030 and when i hit copy all i get is black page.
- clean the scanner optics
- if this don't work check and replace drum cleaning blade
Jul 26, 2012 | Minolta EP1030/1030F CS/PRO Copier
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
Dec 16, 2011 | Dell 948 All-In-One InkJet Printer
When I try to print a page from the web, it prints what looks like code. It will not print the actual page that is front of me on the web. However, if print from Word Perfect, it is fine.
It's not your printer problem. The web page size is different from paper size. For these reson when you select whole web page, the web page divide more sector and at these time your printer print one of them or more.
Here is a software that help you to print the web pagehttp://www.printpunk.com/downloads.htm
Or,
There are some web site to print web page.
Jast go to the web, paste expected web address and try to print.
Or
If you are wondering why you can't just click the print command and get the web page or other internet page you're looking at to print out properly, you're not alone. Too often pages get cut off at the margin so the ends of lines are missing or pictures are cut off, or blanks appear where words or images should be. This is pretty frustrating because you can see the words right there on the screen; they're there, but when you print them out they're gone.
Never fear-- we a have a few how to tips and tricks for you to get those internet pages to print out nice, neat and complete.
First Click on Print Preview
Before you print out a page, go to your browser menu (usually the file menu) and click on print preview. This will bring up images of the web pages as they will appear on a print out. If they look good, all you should have to do is click the print command, usually also found in the browser menu file window, and they will print out as shown. Note, however, that once in a great while the print preview will not be accurate, and the print out will not match the preview. But don't tear your hair out, just make use of the tips that follow.
Look for the Printer Friendly Link
Some pages will have a "printer friendly" or "printable version" link or the like. Click on this link and you will get a version of the web page or pages that is optimized for print out. Once you have brought up this printer friendly version, just click on your print command found in your internet browser window. You might still have some problems if you are printing on a black and white printer, which we will discuss later, but otherwise you should get a faithful print out.
Also Look for the Pdf File Link
If the page you've called up comes up as a pdf file, you should have no problem printing it. If it is the usual html file, it may also have a link that will take you to a pdf file version of the same pages. Look for this pdf file link and click on it to bring up the pdf file. To read this pdf file, you will need a copy of adobe acrobat, which you can download for free by clicking on this adobe acrobat link. Remember that once you're in a pdf file, you should click on the print command in the pdf file menu, not on the print command found in your internet browser window. Clicking on the browser print command may cause all kinds of problems, depending on how your computer is configured.
Print in Landscape Instead of Portrait
If the print preview shows pages cut off on the margin, and you don't have a access to printer friendly or pdf versions, you can print the pages out in landscape instead of portrait format. If you don't know already, landscape prints left to right across the longest dimension of the page (as in a landscape painting) and portrait prints out the normal way (as in a portrait painting). When you print in landscape, you are pretty much guaranteed that nothing will get cut off at the margins. In most browsers, you go to the file menu, click on 'page setup', and in the page setup window click check the landscape box before you do your print out.
Black and White Printer Problems
Some black and white printers do not convert all the colors to black or gray causing some elements of pages not to print out at all. You get blanks spaces instead of words or picture. I have a black and white printer that does not print out blue. This is really aggravating when printing out text that contains a lot of those blue underlined links. You are reading a sentence and suddenly there are missing words.
There are a couple of solutions here. The obvious one is to print out the pages on a color printer or a different black and white printer that does not have this problem. Another solution is to cut and paste the web page into another program such as a word processing program. In many cases you can just then print out the pages and they will print fine. In other cases you will have to use the software program (that you've just pasted the page into) to change the problem color portions to black and white, and then print out the pages.
Problems Photocopying Web Page Print Outs
Sometimes a page prints out fine on a color printer, but you have problems copying color portions on a black and white photocopier. A lot of photocopiers don't copy yellow well. This may be intentional, as it allows you to get good copies of things written on yellow legal pads, and to eliminate yellow highlighter marks from pages you have marked up. However if the yellow is content you want to keep, it just gets lost. Try another photocopier; they don't all do this. Alternatively, print out on a black and white printer before you photocopy.
When All Else Fails
If you still can't print out successfully, you can try another web browser, or you can email the webmaster or other contact for that website and ask for a fix, copy of their catalog or whatever ot
Aug 30, 2011 | Office Equipment & Supplies
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Line down page when I print
If youre getting a line when you are printing, the problem probably lies with the drum. Open up the cover and see if there are any black lines. If there are, the drum needs to be replaced.
Aug 18, 2008 | Office Equipment & Supplies
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Brother MFC 7420 All-In-One Laser Printer Logo
552 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
