Question about Dryers
My dry blow out cool air model ler4600pq
this is a whirlpool. the model ler4600pq
  • Dryers Master
  • 8,220 Answers
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Remove and clean the venting to outside then get the rear cover off and check for continuity to the heater element and safetys.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 30, 2010
I have a whirlpool unit model number ED22MMXRNRO the lights are on inside but the unit is nor cooling.
Is the fan inside the freezer is blowing air. But not cold air and it is regular air. If so then your compressor is not running or there is a cooling gas leak or line block.
Oct 14, 2014 | Whirlpool Refrigerators
Whirlpool dryer overheats, heats on air only
Sounds like heating element may be grounding out.
Oct 27, 2017 | Whirlpool Dryers
I have a whirlpool dryer and it is no longer drying. it blows cool air and tumbles.
Check the gas connections are tight. Also check the gas shut off is turned on.
Aug 16, 2010 | Whirlpool LER4634J Electric Dryer
Will not heat to dry it blows cool air not hot enough to dry the clothes
If you have a gas dryer then check out this tip...
If you have an electric dryer then check out the tips at the bottom of this tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 22, 2010 | Whirlpool Dryers
WHIRLPOOL model: cem2760tq heating problem
HAVE YOU CHECK THE HEATING ELEMENT? THEREMAL FUSE? USE AN OHM METER, IF YOU DON'T HAVE CONTINUITY, REPLACE IT. CHECK THE FUSE FIRST, IT'S LESS EXPENSIVE
Jan 15, 2010 | Dryers
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Whirlpool ACE244XS air conditioner blows out cool air when on hea
Due to Defective Thermostate Switch Try to Replace, will be ok
Nov 18, 2008 | Whirlpool ACE244XS Air Conditioner
Dryers Logo
71 people viewed this question
Top Dryers Experts
