Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Jenn-air electric double control does not work - clock is on
I have a Jenn-air electric double wall oven circa 2004. The oven control panel started to beep with increasing frequency. It ceased suddenly after my son repeatedly pushed the cancel button. Now all buttons beep when pushed, but there is no function. The clock still works. I recycled the power to no effect.
  • 2 more comments
  • moore_gary Jan 30, 2010
    I have no error message. I cycled the power till the count of 30 - the clock did not need to be reset - is there a capacitor or inductance ? I will turn it off until the clock needs to be reset - how long it that typically>
    I do not get any error messages. The oven date from mid-2004, The panel is a double panel for both ovens. Both ovens are affected. Timers and other keypad items do not work - the oven light comes on only when the door is opened.
    A 2 hour power reset was conducted with no change the clock interstingly came back with the same time as when I cut power 2 hours ago. The control panel still doe not do anything. The timer does not work - nothing on the control panel is responding except to beep when one pushes the button. Both upper and lower ovens are affected (single control touchpad) Number on the door frame is 8114P955-60
  • moore_gary Jan 31, 2010
    I get beeps when I push buttons - previously when I had a sabbath mode issue there were no beeps - the units is not in sabbath mode.
  • 10,515 Answers
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
  • Jenn-Air Master
  • 2,605 Answers
I`ll start with a question, if the answer is NO, you may want to locate one. The question is. Do you have the owner`s manual/operation guide ? If the answer is YES, look to see if your oven has some how been entered into a "sabbath" mode. Many modern oven`s (especially hi-end unit`s like your`s) have this feature which can be entered into the control which default`s the oven to not allow any function`s to take place until the unit has the "sabbath" mode exited/turnes off.
If you don`t have a manual, you may want to inquire on-line about getting one as it sound`s like this could be the problem with the oven`s, which in fact isn`t a problem at all and that would be great.
Good luck. Let me know if I can assist you further.
macmarkus :)
  • 3,741 Answers
The control panel is got short internally and that has to be replaced. the timer is ok and the door and door switches are ok and in working condition.
the control panel is got short.
it has to be checked and replaced.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
My Jenn Air Electric Wall Oven Control panel lights have gone out
You will need to replace the display assbly.
It is a very common problem with maytag/Jenn Air
Feb 19, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Dec 07, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
393 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
