Question about Toshiba Satellite P200-0TD00Y Notebook
Power On, Fans start but stop in few seconds and that's all
When I press on the Start button, the power light comes ON and stays ON.
The fans start but stop in few seconds and then nothing more happens. Nothing on the screen.
If I continue to press the start button for few seconds, power is cutting off as usual.
It seems like a protection stops the boot to operate.
I test the RAM modules.
I test the CPU.
I test with battery and without battery.
I test the HD.
I've removed the DVD player.
Now I have on the table just the motherboard and I always have the same thing.
Have you please an idea about the reason of this phenomenon.
Thanks Christos
  • 62 Answers
May be there is a problem in the windows, but suppose it is not booting at all.
First Check once more your boot options from bios menu
Second If it still the same thing, extract your battery out of your laptop for 12 min, then try to power up your laptop pluging in your power cable(don't use your battery)
Third If it still not working, there must be a problem in your cooling fan, so check it, also check your motherboard & your graphics card (Most of this problems happens due to a problem in the computer cooling system in motherboard & graphics card)
Hope it works for you Christos
Posted on Jan 30, 2010
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
Gateway 831gm - press power on, power is there but will not stay
If the power button is not defective in/out, it means yuo have a defective power supply.
Thanks
Jul 30, 2010 | Gateway Computers & Internet
My hp laptop will not boot up
Check the power supply for power. Replace if necessary. Also check the motherboard for proper operation. If no fans come on or only come on for a few seconds then you have a bad motherboard
Feb 14, 2009 | Computers & Internet
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
CPU does not start
Hi, have you tried removing all the cards (video, lan etc) and all power connectors to drives? Run only your mb. If problem persists then it is possible that there is a short in the mb since the psu auto protects and shutoff. You can also try removing the retaining screws of the mb and try running it completely off the back panel. Care should be taken to ensure that the back of the mb does not touch any metal part of the casing. You can try sliding in between a plastic folder or something. If psu still shuts off, then you it is most likely the mb is fried. Please let me know if this works out for you. Regards
Apr 09, 2007 | Intel D865GLC Motherboard
Open Questions:
Toshiba Satellite P200-0TD00Y Notebook Logo
368 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
