I must be missing something but the mini usb cable does not appear to fit in the port on the Action Replay...
SOURCE: Action Replay for Nintendo DS
Sorry, my last desc should be ignored here are all to solutions to problems. I know:
Prob: Two white Screens:
Solution: none so far, have emails sent to Datel. see what happens. This occurs when attempting save codes with the DS and the AR is pulled out or DS powered off. My suggestion if you get a new one, only update codes using the PC software.
Prob: AR keeps asking for game cart. insertion:
Solution: remove AR and put in game cart.
Prob: AR not enough memory to update codes:
Solution: there is more bugs in their software/firmware that doesn't really know when items are deleted and space is free. You must reset AR cart. and then use the PC software to reload all the codes:
a) First I would update the AR PC software (no DS AR connected)
b) Connect DS with AR to PC then update the AR firmware
c) Disconnect DS AR from PC
d) DS off hold A+B when TURN ON DS when DS logo shows press START+SELECT with A+B still down as well, hold for a while. turn off DS
e) Reconnect to PC, turn on DS and drag the PC US codes to the DS side. (Note: I had to do 4 & 5 a couple of times it finally worked)
Prob: AR PC software not seeing the DS AR connection: Solution: The PC drivers are not being found for the NDS link. You need to do the following:
a) close the AR PC software, and disconnect the AR DS.
b) connect the AR DS and then the windows new hardware driver install window pops up. must select using the manual browse option.
c) go the the action replay directory either on the action replay CD you bought or from a extracted version from the web. (NOTE: this is not the installed location, but before where the setup.exe exists) I had lost my CD and did about 10 minutes and found a .rar of the source code.
d) pick the action replay subdirectory and click on install
e) you should see the NDS link drivers being installed.
f) start the AR PC software and attempt to connect the DS AR it should work.
-- I hope this helps anyone --
SOURCE: Erased Action Replay
Follow the reset proceedure in the manual. Had this problem several times and it always worked.
SOURCE: action replay code maniger dose not detect my action replay
I have had the same problem. I found what solved it was going into system properties, device manager, and finding in "other devices" the device called NDS link with the error triangle on it, then clicking "update driver".
This is assuming that you have the original cd. According to others on the internet if you download the software from the site, it does not seem to include the drivers.
SOURCE: action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
SOURCE: my action replay code manager is empty and I want to add pokemon
Heres your problem, I believe you just recently purchased this AR, the new version of action replay require a software update found on Datel's website, after downloading this software your Domain Suffix of your Optical Drive will automatically replace the program with the newer one. Open up your winsock processor and buffer the Native file of your AR back into your fluxus core before adding codes to your action replay, if this does not fix the problem, submit a complaint to the Datel Hacking Team located at PO box 45265 North Ridge, CA. This whole process should take anywhere from 10-12 weeks to fully resolve
