Question about Hotpoint VBXR1090D Top Load Washer
Water wont drain
My water wont drain, ny clothes are sitting in water
    Sniper:
  • 65 Answers
Can you manually set it to spin? if nothing happens when you do that then check your lid switch
Posted on Feb 18, 2008
Wont spin drain or engage
Need more info. Brand, top load or front load, or full model number. Thanks.
Jan 19, 2013 | Washing Machines
My Whirlpool washer wont soak up the water during the rinse cycle. So my clothes plate sitting in dirty water. I have checked connections and turned breaker of washer on and off twice, and it still won't...
Check the drain is not clogged. Check the water outlet pipe is draining downwards. Remove outlet pipe from the back and look in with a flashlight to see if there is an obstruction.
Aug 17, 2010 | Whirlpool Washing Machines
Our Electrolux front loadeing washer wont drain, and now it wont unlock! clothes are sitting in water and we cant open the door to get them out. Oh yeah...its giving us an E-21 error code. No...
You will have to get the water out,down by the filter at bottom lhs see if there is a small rubber hose next to filter if there is it should pull out so far then you can remove the small plug on end to drain into a container.If no hose down then try putting the drain hose down to floor level into a bucket or out of an exit door to syphon out water.Or get machine filter by an exit door and release the filter plug and let water drain out.E21 means that there is either some blockage in the pump or the drain pipe may be kinked or blocked.
Apr 19, 2010 | Electrolux EW1000i Front Load Washer
Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Dec 16, 2009 | Asko W600
My washer wont hold water
Hi
Make sure your drain hose is not sitting on the floor.
You need to make sure the drain hose goes up to the hight of the tank and then back down to the drain.
If the hose is sitting low, then gravity will just drain the water out.
Let me know if this is not the case and I will dry and diagnose if there is a nother problem.
Ash
Nov 06, 2009 | GE WBSR3140DW Top Load Washer
Water is not draining. Clothes sit soaking in still water
drain hose kinked not letting all the water out , or the belt is slipping and water pump not pumping all the water out.
Aug 12, 2009 | Washing Machines
Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Oct 27, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Kenmore washer not draining water
check for defective lid switch or switch just out of adjustment.
Aug 24, 2008 | Washing Machines
Washer wont drain water
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
77 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
