1. Press the four
buttons for your personal entry PIN, then press and hold the *
button. The opener light will blink three times. Release the button.
2. Press the temporary 4
digit PIN you have chosen, then press ENTER. The opener will blink
four times.
3. To set the number of
hours this temporary PIN will work, press the number of hours (up to
255), then press *.
OR
times this temporary PIN will work, press the number of time (up to
255), then press #. The opener light will blink once when the
temporary PIN has been learned.
Test by pressing the
four buttons for the temporary PIN, then press Enter. The door should
move. If the temporary PIN was set to a certain number of openings,
remember that the test has used up one opening. To clear the
temporary password, repeat steps 1-3, setting the number of hours or
times to 0 in step 3.
The 4½
minute interval can be changed to 1½, 2½ or 3½ minutes as follows:
Press and hold the Lock button until the light blinks (about 10
seconds). A single blink indicates the the time is reset to 1½
minutes. Repeat the procedure and the light will blink twice,
resetting the timer to 2½ minutes. Repeat again for a 3½ minute
interval, etc., up to a maximum of 4 blinks and 4½ minutes.
It sounds like your chain may be out of sync with the limit switch. You can try this.
Loosen the chain enough
so that you can remove it from the sprocket above the motor unit.
With the door closed run the motor until the sprocket turns clockwise
and stops. With everything attached replace and tighten the chain.
Some adjusting of the up and down limits will probably be required.
