Question about Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-65WV700 65
Small black spider like lines on screen. not on screen protector.
  • martinezfam Feb 18, 2008
    where is the picture tube magnifier located?
    Novelist:
    Champion:
  • 211 Answers
This may be nothing more than dirt, hair or dust on the picture tube magnifier glass ( you can clean this by opening the front and cleaning like you would a window glass) or it may be more serious like a high voltage divider control. I would suggest you try cleaning the tubes first and if it's not that, then seek qualified help. ( PS. Always unplug the set from the wall before working inside the set ).
I hope this has helped.
Happy President Day.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
  • Ed Meshechek
    Ed Meshechek Feb 18, 2008
    The Picture Tube magnifiers are lenses located on the top of each picture tube. They are inside the set on the bottom, pointing up toward the mirror. Remember to unplug the TV before you work inside the set.
    There are 3 tubes ( 1 each RED, BLUE, GREEN ) Clean all of them along with the glass/plastic screen on the inside of the set while you have it opened. Also clean the mirror. Good Luck
    Ed
    NC Electronics
    Mills, Wyoming
Blue lines in screen
Follow the steps below after verifying that the issue is occuring on other channels and other video sources.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved, service may be required.
Sep 22, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a spider web behind the screen, how do i
sometimes on sony TV's on the sides you will have a door, that you can open with a screwdriver. if yours have it you might be able to dlean all that web from both sides, if not its a little bit more complex.
Jun 25, 2009 | Sony KP-53HS30 53" Rear Projection...
Screen protector broken
The protective screen is part # 409088101 and is available from tritronicsinc.com for $103.01
Dan
Dec 15, 2008 | Sony KP-57WS500 57" Rear Projection...
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-51HW40 51 Screen Protector
this tv has three parts to screen , the most outer part is called CONTRAST screen part # 408195411 for the model you gave.This is available @ sony.com (parts&access) Please make sure this what you need and model is correct..Good luck
Nov 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Nov 06, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Sony KP-65WV700 65" Rear Projection HDTV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
