Question about Dell Inspiron 6400 Notebook
Started up my dell inspiration 4100 laptop and it says no primary boot up devices and makes a click noise ,i went into the bios setup and it says down the list harddrive none constantly please help as just an hour ago it was fine ,
  • 62 Answers
You must remove the battery for 12 min, and start your computer with the power cable.
Try opening the bios setup and change the boot order making harddrive no.1 in the boot order.
If all that not working, just press F12 and setup a new windows copy, may be the windows copy is damaged.
Posted on Jan 30, 2010
My Dell Windows 7 laptop won't boot?
Press the Delete key during start up, to enter its bios settings window. At boot sequence selection, select CD ROM as first boot device, Hard disc to second boot device, and deselect all other boot devices. Means, there should be only CD ROM and Hard disc as boot devices, as said above, in sequence. Select 'Save and reboot' at the bios option, the computer will restart with hard disc; provided there is no CD at CD ROM. Gopakumar Gopalan Google
May 10, 2014 | Dell Computers & Internet
How to make CD Rom run as BOOT? please key in
Go into the BIOS and change the boot startup device order. Make the CD the first boot device and the hard disk the second boot device.
If you do not wish to change the BIOS you may select the CD drive as an alternate boot device by pressing F10 or F!2 as the laptop boots up to bring up a list of devices to want to boot from, select the CD drive and the follow the screen prompt.
Aug 29, 2011 | Dell Inspiron 1525 Notebook
When I turn on my Laptop the Dell Inspirer E1505 it says A Disk Read error occured Press Ctrl + Alt + Dell to restart then i restarted the computer i pressed F2 and the BIOS setting came up i went to...
It's asking you for a password to access the BIOS. You or someone entered a password to access the BOIS (setup screen). The original problem you're having is "Disk Read Error". If you have the CD's that came with your laptop, look for a Resource CD or any that has "Utilities and Diagnostics" under "Contents". This is a CD that you can boot from. Insert the CD and select <F12> on power on. Select boot from CD/DVD disk. If the laptop boots then your laptop is working but your hard disk drive or OS (Operating system software) is the problem.
Jan 09, 2011 | Dell Inspiron E1505 Notebook
Loading a new 500 gb onto a dell latitude d410 and when i go to boot up the new system i get the following message: No Bootable Devices-strike F1 To Reboot F2 For Setup
you haven't set your bios and or your setup to read the new device ok so go to the bios f11 or in setup f2 make sure the the setting in these are set to primary under your new HD name should be there if it see's it do in the bios and in the setup and should work for ya. ! the fixist good luck and have a nice day
Jul 01, 2010 | Dell Latitude D410 Notebook
How to remove bios password from inspiron 4100
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-4100-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Nov 04, 2009 | Dell Inspiron 4100/8100 Notebook
No boot device
A boot device is typically the main hard drive which contains your operating system.
There are a couple of reasons you'll get this message:
  1. You or somebody else modified the BIOS and disabled the bootable hard drive. To fix this, turn the computer on and watch for a prompt that includes the words BIOS or SETUP. It should have a key associated with it (F2 and Delete are two common options). Look for the boot up section and make sure that your primary hard drive is on the list (usually 1st or 2nd in the boot sequence.).
  2. Your hard drive is damaged or the boot sector is damaged and the BIOS can't find the boot information. In this case, I would take the computer to a local professional. Your hard drive may not be recoverable.
Oct 14, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell logo appears and message appears INSERT BOOT DISKETTE...
A couple of things can cause this.
1] having the 'boot order' set up so that the computer looks to a removable device that has non-bootable media in it.
2] somehow the 'boot' device has lost it's 'boot' properties.
Best way to troubleshoot:
1] find the boot CD
2] re-strat the machine and enter the "BIOS setup" mode <f10>, or <DEL>; I think::verify the boot order
this should likely be: C: ; CD ; A:
allow machine to start with CD and check to see if anything on the wanted 'boot' device has been lost; sometimes it will get smashed.
Let us know what you get after this point, because I would rather give you an answer based on knowledge from this part of the exercise.
Mar 21, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Inspiron 6400 Notebook Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
