Question about Whirlpool Kitchen Ranges
Hello:\r\nWhen I oven start button the panel show
Hello: When I oven start button the panel show E3 in red and -F1- in black. The oven will not start. It is a Whirlpool model #
WEP84801 and the serial # is
IMH1663718
  • 10,515 Answers
Disconnect the Power for 10 minutes and then Turn ON the Oven. If the same Error Pops up, you need to Replace Control Board.
Usually Most of the Parts have 5 Years Warranty. You need to Check the Manual Offered to You or Contact Whirlpool to confirm the same.The Cost of the part would be around $175.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
E3 -F1- this message just started showing up on the display of my Kenmore Ultra Bake Oven Md#66575842003
Hello there and thank you for choosing fixya
The E3-F1 ERROR CODE is a fault code that tells the consumer that the ovens main controle panel has a problem
This could simply be a wire that has came loose but a lot of the time the controle panel has failed and will need to be replaced
Here is what you can do
First disconnect the power Totally and slide the oven out and if you can remove the back of the unit and check to see if there are any wires that are loose or really greasy if so clean them and replace them also remove the panel at the top to expose the control board and do the same thing as in the previous step.
If you can find the wire harness look for the place where it attaches to the board and disconnect it then wait 30 seconds and reattach it.
after this has been completed leave the oven unplugged for at least 45 min total to allow for the internal reset feature to attempt to reset the memory feature on the oven then replace the back of the oven and any other parts that may have been removed
plug in the oven and press the cancel button if the error is still showing then yes the board is fried and a new one will have to be installed ok?
Hope this is very helpful for you
Best regards mike
May 03, 2011 | Kenmore Ovens
Our oven keeps saying E3 F1 when attempting to preheat. We bought the oven used and didn't get a manual w/it... Any ideas?
Hello & Welcome to FixYa
F1-E3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Microwave Ovens
My oven is showing a code E3 (in red) -F1- (in black). Everything works but the heat light will not stay on and it will not heat. It has a safty feature that when the electricity goes off you have to reset...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Whirlpool Ovens
Error E# and F1
Hello,the error codes E3 and F1 means Wiring harness cavity size does not match previous stored valued
SOLUTION:The "Cavity Size Select"jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for.
Check the jumpers in the harness to make sure they agree with the actual oven size.
Thanks
Jun 01, 2010 | Whirlpool RBS245PDS Electric Single Oven
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
E3 F1 code on key pad kenmore specail edition
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 17, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Error code on my oven, what does it mean?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
Nov 15, 2008 | Whirlpool RBS305PDS Electric Single Oven
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
Error Code F1:E3
reprogram the control board as following:press buttons on range
power off wait 5 sec
power on wait 5 sec
convection broil
clean
backed goods
stop time
190
timer set
start button 12 times(it will go through all the settings)
Mar 17, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
21 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
