Question about Watches
I can't get the day indicator to move into position on my Zodiac
I can't get the day to move into position as per the instructions. The day window says ''SAM''. I have pulled out the stem into position 2 and turned it counterclockwise per the instructions put nothing happens.
    President:
  • 2,501 Answers
SAM is German for Saturday (Samstag). Your watch is set to German! Is it possible to change language?
If you can't find anything about this in your instructions, have a word with your nearest dealer for your watch.
To find your nearest dealer go to their web site and look for something like "store finder".
Posted on Jan 31, 2010
Testimonial: "Thanks, David. I kept turning the watch's stem and it moved for Sam to Saturday!"
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
Tip
Watch glossary: U, V, W, Z.
UNIDIRECTIONAL ROTATING BEZEL
An elapsed time rotating bezel, often found on divers' watches, that moves only in a counterclockwise direction. It is designed to prevent a diver who has unwittingly knocked the bezel off its original position from overestimating his remaining air supply. Because the bezel moves in only one direction, the diver can err only on the side of safety when timing his dive. Many divers' watches are ratcheted, so that they lock into place for greater safety.
UNIVERSAL TIME
The mean solar time of the Greenwich meridian, counted from noon to noon, Often confused with the mean time notion.
VARIATION
In horology the term is usually referred to the variation of the daily rate, i.e. the difference between two daily rates specified by a time interval.
VIBRATION
Movement of a pendulum or other oscillating bodies, limited by two consecutive extreme positions. In an alternate (pendulum or balance) movement, a vibration is a half of an oscillation. The number of hourly vibrations corresponds to the frequency of a watch movement, determined by the mass and diameter of a balance and the elastic force of the balance spring. The number of vibrations per hour (vph) determines the breaking up of time (the "steps of a second hand). For instance, 18,000 vph equals a vibration duration of 1/5 second; in the same way 21,600 vph = 1/6 second; 28,800 vph = 1/8 second; 36,000 vph = 1/10 second. Until the 1950s, wristwatches worked mostly at a frequency of 18,000 vph; later, higher frequencies were adopted to produce a lower percentage of irregularities to the rate. Today, the most common frequency adopted is 28,800 vph, which assures a good precision standard and less lubrication problems than extremely high frequencies, such as 36,000 vph.
WATER RESISTANT or WATERPROOF
A watch whose case is designed in such a way as to resist infiltration by water (3 ATM, or atmospheres, corresponding to a conventional depth of 30 meters; 5 atmospheres, corresponding to a conventional depth of 50 meters.)
WHEEL
Circular element, mostly toothed, combines with an arbor and a pinion to make up a gear. Wheels are normally made of brass, while arbors and pinions are made of steel. The wheels between barrel and escapement make up the so-called train.
WINDING STEM
Element transmitting motion from the crown to the gears governing manual winding and setting.
WINDOW
Aperture in the dial, that allows reading the underlying indication, mainly the date, but also indications concerning a second zone's time or jumping hour.
WORLD TIME
Additional feature of watches provided with a GMT function, displaying the 24 time zones on the dial or bezel, each zone referenced by a city name, providing instantaneous reading of the time of any country.
ZONE
Small additional dial or indicator that may be positioned, or placed off-center on the main dial, used for the display of various functions (e.g. second counters).
ZODIAC
Circular belt with the ecliptic in the middle containing the twelve constellations through which the sun seems to pass in the course of a year.
on Jan 11, 2010 | Watches
Set reserve indicator on invicta 6106
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Jan 03, 2012 | Invicta Reserve Watches
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
Just been given an Audemars watch - don't know how to set it.
I was unable to find any instructions on their web site, so if you haven't got the instructions, then I suggest you try ringing them on one of the numbers below. (You might ask them for a set of instructions as well as how to solve your problem).
Toll Free: (800) 595-5330
Phone: (239) 262-4545
Jan 31, 2010 | Audemars Piguet Watch
How do I close the stem on a zodiac watch?
Your watch do not have screw down crown feature. You can only pull out or push in that crown.
Check instructions for yourself from the official Zodiac document here:
https://www.zodiacwatches.com/images/pdf/zodiac_watchinstructions.pdf
Rate me, please.
Mar 14, 2009 | Zodiac "Sea Dragon" Watch
How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Sep 29, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Apr 23, 2008 | Pulsar PXF106 Wrist Watch
Watches Logo
64 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
