Question about Sanyo DP32649 31.5 in. TV
Sanyo DP32649 works fine for a few minute, then sound goes off. turning the TV off for a moment & then back on restores the sound. But sometimes this will happen ever few minutes for the length of the program.
  • Anonymous Mar 13, 2014
    The video on my Sanyo dp42840 won't come on sometimes, even though I get the audio. I unplug it for a while & after plugging it back in, the video & audio come on. This has happened 5 times lately. I only have my TV on at night 2-3 hours.
  • Anonymous Mar 28, 2014
    What could be the problem? And what would it cost to fix?
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Posted on Feb 21, 2010
  • wmrench Oct 15, 2010
    We just had same problem begin with this model. It was also bought at Walmart. We have used it less than 6 hours a week for less than a year. Sound was never good. at average volume it buzzed the wimpy speakers. I also, someone else commented, could smell a hot electronics smell near the top out the unit. Now sound quits every 10 minutes, and tv must be turned off and on to restore. I'm hoping to get it covered but its close to one year. Man, the old tube TVs we had lasted years longer. Last Sanyo product I'll be buying.
Sanyo dp32649 on light comes on but know picture or sound what can I do to fix this ?
This is likely a power board failure. Check that this board has blown caps and replace the caps with the exact part and make. This is usually a $10 fix.
Jun 01, 2014 | Sanyo DP32649 31.5 in. TV
Video is blurred
my tv has perfect focus button plus focus adjustments under panel in back
Dec 31, 2011 | Sanyo DP32649 31.5 in. TV
My Sanyo is a year old. We got a new cable box, plugged in in and it worked fine for about 10 minutes. Then the volume spiked very loud, it glitched, shut off for 10 seconds, and then comes back on. It...
Hello roby, hi, to find if the problem is the cable box or the TV, try using another TV. if the cable box performs normally, you have a problematic TV. Otherwise its the cable box.
Dec 04, 2010 | Sanyo DP32649 31.5 in. TV
Tv will turn on for a few seconeds then turns its self off
Tries tv unplug,replug it back like an hour later.The tv is resetting itself back to the factory setting now.The tv now should work,not than the tv have problems with it power supply board.The power supply board it not giving the tv,the wright voltages to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 14, 2010 | Sanyo DP32649 31.5 in. TV
My Sanyo DP32649 Will not turn on. The green light turns on and off when I press the power button but that's it. there's no sound and the screen just stays black.
Sounds like the power supply is bad.Do you know anything about working on circuit boards ? I bet some of the capacitors need replacing.This is a quick and very cheap fix if you know how to do it.
On the back of the tv is a panel held by two screws.Remove those and you have instant access to the power supply.Look and see if any of the capacitors are bulging or leaking.
Mar 14, 2010 | Sanyo DP32649 31.5 in. TV
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Sanyo DP32649 31.5 in. TV Logo
785 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
