Question about Nuvico NVDV3-16000N
Check the system HDD
I have a nuvico DVR8000 for 8 channel it keep saying check system HDD and make a noise which wont go away can u please help me with that
2 Suggested Answers
SOURCE: problems with a dv3 16000 Nuvico digital recorder
We do not use the dvd recorder that comes with the dvr. We put it on our network and use the software utility to pull off any file footage we need. Though it is in a format does not allow you to play it back on a standard dvr (you must use the file viewer and a pc) it is very easy to get the footage off.
Posted on Aug 08, 2009
Nuvico ED-C1600 can not set time
Is there a button cell inside that has become exhausted?
Mar 10, 2015 | Nuvico NVC-EDC1610 16-Channel EasyNet...
I have a Nuvico 16000 Getting error message "Check the system: HDD Help!
The user manual does not help with this error. Sometimes there is a reset procedure, but I could not find something like that.
Perhaps you try to get some support form Nuvico on this page:
Nuvico
PS the manual is still online.
Nov 20, 2014 | Computers & Internet
Okay i am trying to connect my wii to the access point because i have wireless internet well when i finish putting in the passcode which i find on the router and it says testing connection well it say...
Hope this solution helps!
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Sep 04, 2011 | Nintendo Wii Console
Getting a system alarm - HDD FAIL. Does this mean I need to replace the internal hard drive. If so, what hard drive is compatable with this unit?
Depending on how new the system is, you should check with either the store or the manufacturer, and see if it is still in warranty. If not, and you would like to replace the drive, open up the unit, and pull out the old drive, look up the model number online, and order the same model/type. seeing this is a newer model, I believe it will be a sata drive, unless they made their own special connector for their own devices.
May 05, 2011 | Nuvico AL-1610 16 Channel Apex Lite Series...
Problems with a dv3 16000 Nuvico digital recorder
did u try using a cd cleaner the dvr only accepts cdr not dvd try using the usb port with a thumb drive to see what happens
Jul 05, 2009 | Nuvico NVDV3-16000N
HHD Error
you need to replace the hard drive.
Jan 13, 2009 | Nuvico NVDV-4080N
Motion detection problem with surveillance cameras
under motion settings you must select all or parts of the screen to be viewed.you may have them all unselected.
Oct 27, 2008 | Nuvico NVJV-4000N Video Recorder
Nuvico NVDV3-16000N Logo
368 people viewed this question
Top Nuvico Televison & Video Experts
Are you a Nuvico Televison and Video Expert? Answer questions, earn points and help others
