Question about Samsung HL-P5063W 50" Rear Projection HDTV
WORKS FOR ABOUT 5 MINS.THEN LAMP GOES OUT.CAN'T TURN TV OFF BY PUSHING BUTTON ON FRONT.HAVE TO PULL PLUG.I RECENTLY REPLACED LAMP
  • 1 more comment
  • jjbell74 Jan 31, 2010
    RESET LAMP TIMER.TURNED ON TV,GOOD PICTURE AND SOUND FOR 2 MINS.THEN SCREEN GOES BLACK,LAMP GOES OFF.NEED TO UNPLUG TO RESET.NO BLINKING LIGHTS ON FRONT.SOUND OK.
    i reset lamp timer,then tried again.picture and sound fine for 2 mins.a couple of blips on screen then goes dark.lamp goes out,sound is fine.no lights on front blinking.controls freeze.
  • jjbell74 Feb 01, 2010
    picture was dark so i replaced lamp;no lights blinking on front when lamp goes out;everything thing is quiet only sound from whatever station was on;new problem after lamp replacement.everything seems to be normal except lamp goes out.
  • Samsung Master
  • 5,138 Answers
Ballast Board Part# BP47-00021A or BP47-00027A This part is what powers Lamp Also CK Lamp Fan if it stops Cooling Lamp TV will shut off to protect Lamp from burning up.Call UED 1-800-648-6657
OR Look on E-Bay under Electronics Parts. This Set has 3 Fans Lamp Fan, DMD Fan and the Ballast Fan.
Posted on Feb 01, 2010
  • 201 Answers
When the lamp goes out are there any lights blinking in the front? If so which ones? Did you replace the lamp because it was already doing this or is this a new issue? Do you hear that little melody play when the lamp goes out? Do you hear any noise coming from the back of the tv like a fan hitting something? Sorry to ask so many questions but unfortunately there are plenty of things that can cause shut down. thx
  • 4,889 Answers
That sounds like a ballast board issue. What is the status of the standby power LED and lamp LED at the front?
Posted on Jan 31, 2010
  • 15,935 Answers
Have you reset the lamp timer?
Are there any lights blinking on the front panel?
There is a limit on the lamp housing hatch - be sure it is properly engaging as well.
Thanks!
Manual for replacing lamp for 60v500a
1. Turn off the main power switch and unplug the power cord. Wait at least 30 minutes to allow the lamp to cool down before
replacing it.
2. Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on
disengages.
3. Remove the screw securing the lamp cover with a Phillips head screw driver. Remove the lamp cover.
4. Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers.
5. Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly.
6. Without installing the lamp cover, the power will be off and the Lamp Indicator will flash. Be sure to install the lamp
cover by re-engaging the two clips and tighten the screws before turning the power on, otherwise it may cause unusual colors.
7. Install the front cover. Put the front cover back in and align the snap on quick connect then push inwards holding
the left and right side of the front cover until you hear a snap. Push the other snap on gently to make a good fit.
8. Plug power cord into AC outlet and turn on the main power switch.
NOTE: The lamp in this product contains Mercury. Dispose of properly in accordance with applicable environmental
laws. For Recycling and Disposal information, contact your respective governmental agencies or the
Electronic Industries Alliance at www.eiae.org (in the U.S.) or Electronic Product Stewardship Canada at
www.epsc.ca (in Canada).
Jun 24, 2012 | Hitachi Lamp for Hitachi 60V500A -...
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Color recently changed and I cannot get it adjusted properly. Picture goes in and out.
Please do the following steps:
  1. Turn on the television.
  2. Please wait approximately 40 seconds for your TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, press and release the POWER button on the TV set. (The button may be on the front, top or side of the TV.) NOTE: The TV may turn off and then back on.
  5. Release the UP ARROW button.
If the issue does not resolve, please follow these steps:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a samsung hlp 4663w, recently (the week after thanksgiving) the color wheel was squealing, so i replaced it also replaced lamp at the same time cause the picture was getting weak, all was working...
SHOULD HAVE REPLACED THE BALLAST WITH THE LAMP AT THE SAME TIME, YOU MIGHT GET LUCKY AND ONLY HAVE TO REPLACE THE BALLAST, DON;T TURN IT ON ANY MORE OR YOU WILL WASTE THE LAMP
Dec 30, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
The unit turns on and works perfectly for 5-10 minutes then the screen goes black and the sound turns off. I removed the back panel, blew off the dust, and checked the fan. The problem still persists. Sony...
Howdy,
It sounds like your Lamp is bad, part number XL2100.
To replace Lamp:
1) Loosen the screws on rear panel (2 thumb type screws on either side of TV, just behind front panel/spreaker grill).
2) Remove front panel.
3) Loosen the screw with coin or similar object to remove Lamp cover (near left hand side).
4) Loosen the 2 screws that hold the Lamp, then pull out Lamp. Don't force Lamp it should go in easy.
5) Replace the new Lamp and tighten the screws, reattach Lamp cover & tighten screws.
6) Reattach front panel cover.
7) Tighten screws for front panel cover in it's place.
Good Luck, Big Irish.
Dec 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have RCA HD50LPW167 DLP TV with NO Sound and NO Audio. The LED blinks when I turn the TV on but that's all it does. Took it to the local RCA authorized repair shop and they told me that the digiital...
Still sounds like a lamp:
TV won’t turn on
• Press the TV button or ON/OFF button while remote is in TV mode and there’s a source of power to the outlet or outlet strip.
• Make sure the TV is plugged in.
• You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
• Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or fl ashing
section below for more information.
• When you fi rst plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when power is reapplied to the TV. The TV can only be turned
on after the Power indicator goes off.
• Check the wall receptacle (or extension cord) to make sure it is “live” by plugging in something else, such as a lamp.
• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 84.
Remote Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Connections, then Special Features, then
Remote Setup. Choose TV (default).
Power indicator is blinking or fl ashing
If the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on. If the TV doesn’t turn on after 5 minutes and
then the light blinks steadily for one minute, one of the following options is possible:
• Lamp door may be open.Face the back of the TV. Locate the door at the bottom of the TV and close it. Turn off the TV and turn
back on. The lamp should turn on.
You can easily replace the lamp yourself by following the lamp replacement instructions. If your TV is still covered by
the warranty, call 1-866-723-6486 to receive troubleshooting assistance and a lamp replacement.
• If your TV’s warranty has expired, call 1-800-338-0376 to purchase a lamp replacement.
To order the correct lamp, you’ll need to know your TV’s model number, serial number, and lamp type—this
information is listed on the Service Model Number sticker (example of the sticker is shown above). Face the back of
the TV. The sticker is located on the right side of the TV.
Hope this helps :)
Mar 07, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
129 people viewed this question
Jerry Greenberg
Jerry Greenberg
