Question about ASUS Eee PC 2G Surf Notebook
Unable to boot
Hi i wonder if u can help me for some reason when ever i try to boot my asus up it will try to load then reset itself and once more load up it will go on like and i have tired everything is there anything u can think off that might be of some help
TY in advance
    Novelist:
  • 157 Answers
If your notebook uses an AMD processor, what has happened is the notebook has now installed system pack 3. It has a bug which causes this problem.
If you have an AMD and updated to SP3, then follow these instructions to fix your problem:
The link is :
http://support.microsoft.com/kb/953356
Posted on Jan 30, 2010
Testimonial: "thanks so much for u help after taking ur advice it started up with out a problem thanks once more "
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
How can i bypass bios password
Solution 1: Unable to power on the notebook.
1.1: Reset hole available on the bottom?
1.1.1: Reset hole available. --> Use a spiculate pin to tip the reset hole.
1.1.1.1: Problem solved. --> Able to power on.
1.1.1.2: Problem persists. -->1.2
1.1.2: Reset hole unavailable. --> 1.2
1.2: Try to power on just using battery.
1.2.1: Able to power on. --> 1.3
1.2.2: Unable to power on. --> Check the adapter indicator.
1.2.2.1: Adapter indicator on. --> Try to power on just using adapter.
1.2.2.1.1: Able to power on. --> 1.3
1.2.2.1.2: Unable to power on. --> Contact ASUS service center for help.
1.2.2.2: Adapter indicator off. --> Adapter problem, check the cable or contact ASUS service center for help.
1.3: Try to enter the BIOS by pressing F2 button when ASUS logo appears.
1.3.1: Able to enter the BIOS. --> 1.4
1.3.2: Unable to enter the BIOS. --> Contact ASUS service center for help.
1.4: Try to enter the Operation System.
1.4.1: Able to enter the OS. --> Reinstall the OS for a try.
1.4.1.1: Problem solved. --> Able to power on.
1.4.1.2: Problem persists. --> Contact ASUS service center for help.
1.4.2: Unable to enter the OS. --> Contact ASUS service center for help.
this one is copyed.
May 11, 2014 | ASUS Computers & Internet
Hi! My asus notebook wont start up. i got a blinking cursor on the top left corner. none of the function keys seem to work either. I even tried ctr. alt del. but nothing happens. it worked fine...
It would apear that you have a boot sector error. The main system apears to be working. Ctr+Alt+Del will not work because windows is not loaded.
With your rescue disc in the DVD drive, just before it boots up repeadedly press F8 until you get the secondary menu that will let you choose Safe Mode, Restore, Rescue etc. and choose Safe Mode. If it boots all is OK and when it has finished the system should have repaired itself. If it doesn't choose restore, this will try to restore the system. If that doesn't work, Rescue is the only other option.
Hope that helps.
Mar 29, 2011 | ASUS Eee PC 900 Notebook
ASUS Eee PC running Ubuntu will not boot after pressing the power button. I have already taken the battery out, tried ac power only, pressed the reset button, and checked the RAM. The indicator lights are...
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Jun 02, 2010 | ASUS Eee PC 900 PC Notebook
Once booted and desktop loads and all icons then the hour glass is locked on screen. Unable to use mouse or click onto anything. Emachine 580
Please reboot pressing F8 to access safe mode. once there see below
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue.
I would recommend trying CCleaner first to see if this helps you. Please keep in mind this will not rid your system of everything just keep you a float and offer you a fighting chance.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 21, 2010 | E-Machines (T2958) PC Desktop
Unable to load desktop ASUS 1005HA XP SP3
Hi
It seems you are stuck in a windows loading loop
Please do the following
1) Go into safe mode (swith the pc on and keep pressing F8 repeatedly until you have a menu presented to you, from the menu choose safe mode)
2) Once loaded click on Start>Programs>Accessories> System Tools> System restore
And restore your computer back to a point before the update was done
if it still loops when using safe mode through the method shown above then unfortunaltey you will have to reformat the PC
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I would like reset the password of my d33005 motherboard
Go into the BIOS setup to reset the password. Start by rebooting the system. Before the system starts loading the operating system, the computer will give an opportunity to enter the BIOS setup utility. Usually a screen appears saying to press a key to enter the setup utility; i.e. "Hit DEL to enter Setup". You have to know what key the computer is looking for to get to Setup. DEL in used on the a lot of ASUS machines but you may that to refer to a manual or read the screen just before the operating systems to load. Once you get in, look for something related to security settings. Once it is found under the boot tab. Here is where you can reset the motherboard password. Hope this helps.
Dec 15, 2009 | ASUS Computers & Internet
HDD problemon asus motherboard p5rd1-vm
You need to install the SATA drivers that belog to your specific motherboard.
When you are installing Windows thru your Windows CD, there is a moment at teh beginning of the process that you will be asked to press F6 if you want to install 3rd party drivers.
That is your call.
Once the SATA drivers are installed, you will be able to continue with your Windows installation.
Don't forget to rate this answer if it helps.
Dec 11, 2009 | ASUS P5RD1-VM Motherboard
Asus laptop NTLDR missing
Hi supertwins,
Once you deleted the drive C: (You have trashed the operating system.
You're Asus driver CD will not help you at this stage.
Did you receive a restore CD? If yes you load that into the CDROM drive & boot to the CDROM.
(You do not have a restore CD)?
Than you are left with the Windows CD. Load the windows CD into the CD-ROM drive. Power up the notebook. Start pressing the F8 key on the keyboard. Soon you will see a screen that says: Please select boot device: Choose the CD-ROM drive that has the windows CD in it. High light the CDROM & press enter key. Windows should start to load. Follow the instructions on you're screen & install windows. During the install windows will restart & you will see: to load from CD press any key... (DO NOT TOUCH anything! Allow windows to continue all by it's self.
This same screen will come up at lease twice. (Just let it go).
When windows has finished you can than remove the windows CD & load the Asus CD into the notebook. Install all the software on the Asus CD. When finished installing the software from Asus, update windows through windows update service.
Good Luck!
Mike
May 04, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
ASUS Eee PC 2G Surf Notebook Logo
347 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
