Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
How do I access the motor in my bottom dish drawer? I think a piece of plastic broke off the motor rotor assembly. The display flashes F2.
  • Fisher and P... Master
  • 3,247 Answers
If you do not have got your user manual for this unit then refer
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
You get to the point where the instructions say how to clean the filter plate page 24. At this point you see the top of the impeller which is attached to the rotor (this unit does not have the motor - very compact and sophisticated).
With your fingers twist the lock disc that surrounds the impeller until it is released from the slots that hold it in place. Take it out and that frees up the rotor. Pull it out slowly but firmly. You will not damage anything as there are no wires (it is a rotor).
Check inside the cavity for debris. Also see there is no debris sitting inside the drain sump and the channel between the rotor cavity and drain sump. You will need a thin but stiff wire to access this.
Then it is a matter of getting a new rotor and placing it in (about $60).
You can go to your local parts supplier and ask. I don't believe the company dealers will sell direct to you unless you are a certified technician. You may have to carry the broken part with you.
The part number for the rotor assembly is 525884
Hope this helps. The reason for the impeller or rotor breaking is that a hard item like bone piece or seed went through the rotor cavity possibly because the drain filter was not sitting correctly or it was unclean. Also before you start the dishwasher check for any item that could have fallen on the base like cuttlery.
Posted on Jan 30, 2010
LG WM2455HW washer won't spin when loaded
The tub was slipping on the motor and when loaded would not spin. I noted when accessing through the back panel that the rotor bolt was loose, probably from the factory as the unit has been used less than two years. When I inspected the rotor, the plastic insert that is screwed into the rotor housing and provides the splined hole that fits over the splined shaft from the motor/stator, the plastic ridges had been destroyed. There are three screws mounting the plastic piece onto the rotor so it appears that the designers anticipated selling replacement for the plastic piece alone. So far this evening, I've only been able to find complete rotor assemblies costing $100+.
So, bottom line, your rotor may just be loose.
Sep 22, 2012 | LG WM2455 Front Load Washer
Fisher & Paykel Dishdrawer: DD603: Have had motor & rotor assembly replaced - now F-2 code here is goes again. Determined to have husband fix it!! I hope. Company says it is an issue with the...
Hi - F2 error code indicates a failure of the rotor/motor or the sensors, the following notes should give you guys something to check and see which of these has failed..
Error Code - F2
Which LED - Delicate LED
Reasons - The motor has not been sensed rotating
Likely Causes
_ Foreign object has jammed the rotor
_ The rotor has failed
_ The hall sensor has failed
_ The electronic controller has failed
Aug 19, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Both diswashing drawer are running with F1 flashing
We found that the unit was floofing because a thin, white plastic tube behind the drawer had broken. I learned that the plastic tube is to preven the electric cables from kinking when the drawer moves in and out. The broken tube was preventing the seal from working properly and water was getting past it to the bottom of the unit where a water sensor detected it, shut the washer down, and displayed an F1 fault. The simple solution was just to snip the tube off so that it could not reach the lip of the drawer and intefere with the seal.
Jan 13, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 ERROR CODE
HI- Probably the Motor Rotor is bad or there is some glass in the rotor. Remove the large screen in the bottom of the drawer (turn lock-nut counter clockwise) and remove the motor rotor (turn outermost plastic part counter clockwise). Look at the bottom of the rotor, you will see the impellers, these are often chewed-up and rough. If so you'll need to replace the part. Also look the the well you removed it from and check for any glass pieces or debris. You should be able to order this part directly from F/P. Motor Rotor. Hope this helps.
Sep 04, 2010 | Fisher and Paykel DD605BK Dishwasher
Leaking fisher & Paykel DS603 Dishdrawer
i think there is a hole in the grey sump underneath rotor motor, the motor is the grey blades u took out of sump. pull out drawer, take filter tray and rotor motor out of drawer, dry all of water out of drawer , then look underneath unit , pour a little water into drawer and see if it is leaking past motor windings . if it is then there is a hole in the sump. if it doesnt leak from there try looking at the little black drain hose. please turn off power b4 u work on dishwasher do not want any accidents . please reply 4 more help.please tell me what u find. good luck
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer works fine - bottom has F2
F2 indicates a problem with motor rotation. Each unit has it own entity. Top draw has it own motor. Bottom also has its own motor.
Tha is one down, the other still working except for the case of F1 code.
Your case is probably a simple problem: some residues stuck in drain pump port. Here are the simple things to take care of the problem. If it doesn't and leave it for professional.
Unplug the power.
Take off the arm spray.
Take off the bottom stainless steel with a lot of holes out.
You can see a propeller in the center.
Carefully pull it up. It is a round plastic attached with a magnet to function as a rotor for the pump.
Clean it up by washing it with water.
Pay attention to the slot so you can allign it the same way when putting it back.
I broke mine due to the fragile plastic on the vertical sides.
Good luck.
Below here are root causes of the F2 code:
· Foreign matter has jammed the
motor.
· The motor drive electronics or
power supply have failed.
· The rotor is faulty or missing.
· The hall sensor is faulty or
missing
Jul 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Feb 01, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
F2 Code
Fault F2 means the rotor is not rotating. If you say some of the vanes have broken off, they could have been jamming it. This should spin freely with minimal force when installed correctly. If you removed the rotor itself, you do ned to take care when installing it - there are 3 thin plastic legs around the magnet (the blue bit) these fit into 3 slots and you need to line them up very carefully. Once you have it right, it will just drop in. The rotor asembly as a whole is secured by turning the outside clockwise until the 3 points line up with the arrows.
Check the rotor is spinning freely, if not, remove it and check there is nothing lodged undrneath it of that it has been fitted incorrectly.
Re the broken vanes - you could try gluing them but I think it will break. The pump spins at 4200 RPM! You may need to but a new rotor.
Aug 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
64 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
