Question about Sanyo DS27510 27" TV
Just bought this set used and it's in Video2 mode and can't seem to get it off. We have Direct TV satellite, how do we get the channel display to show up?
  • 630 Answers
It may be auto selecting the input. Disconnect the Video 2 and see what happens
Posted on Jan 30, 2010
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Jensen MSR4050G Sirius Ready marine radio
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
May 19, 2008 | Jensen MSR4050G CD Player
Video input
require pin to acces on demand
Dec 26, 2013 | Sanyo DS27930 27" TV
I have Arcam Receiver AVR 300. I bought it used a few months ago and the receiver had worked like a dream. Suddenly, for no apparent reason, there was no sound from the SAT channel/output where the...
Seems you set it to "Stereo Direct" mode. This is an analog only mode, while you are using a digital signal. You can change this with the mode button.
Press menu, on the main menu screen 1, scroll down to stereo direct. Turn this OFF.
This should solve your issue!
~KenjiFox
Jan 07, 2011 | Arcam AVR-200 Receiver
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
RCA TV/VCR combo T13060GY won't go below channel 5
I had a similar trouble with a couple of tv sets, one was a Granada and the other a Sony, but once connected to the satellite or digi-box via the scart socket it seemed to concentrate it's mind and override all the channels - so the tv stops being a tv set but becomes a monitor displaying whatever analogue video signal the digi-box sends to it.
The channels should arrive from the satellite receiver/decoder box and that remote control is all you need and the only thing you need to touch the monitor tv for will be the volume...
Scart sockets and plugs are apt to become dirty and unreliable and are responsible for many problems, including once a blue screen.
May 28, 2017 | RCA T13060GY Combo
TRying to get my PC to TV converter up and running
I just purchased the Kworld 1600 PC to TV Game Box today. I also had the same problem as many others seem to have had. The TV screen displayed only colored bars. After searching on line for troubleshooting ideas I finally was able to correct the problem, thanks to help of people responding to these problems on "FixYa", and I thank you, as I was ready to return the product at a loss of 15% of the cost (restocking fee).
I am using a Toshiba Satelite L350D with Vista Home Premium and a 2005-32"JVC TV.
First ensure that the Monitor Y-cable supplied has been properly installed to your PC and your TV (my first mistake). Each plug is individually identified, that being, TV, monitor, scan cnvtr.
Second, on Vista go to Control Panel, open (Double left click) the personalization icon. You can then open your display settings.click on advanced settings, this will open a window for your graphics card. Click on "List All Modes", use an 800 x 600 High Color Mode, 16 bit, 59 or 60 hertz, hit 'OK' and that window will close.Then hit 'Apply' in the Graphics Card window(the screen will go black and then set itself to the new mode). You may have to try a few different 800 x 600 modes to find the best one for your TV.
Thirdly this converter is only for video, not audio.
For audio you must use a 1/8 stereo plug from your PC headphone jack to an RCA adapter into the Left and Right Audio Input of your TV.
Make sure you are using the same Video Input Section for both your audio and video (Video1, Video2, Video3, you cannot plug the video into Video1 and the audio into Video2).
After setting this converter up on my Laptop I was also able to plug it into my 7+ year old desktop (Cicero P4, XP Home Edition).
I hope grouping these 3 problems into 1 will help others and save them some time and frustration.
Thanks again to everyone on "FixYa" for their help.
Mar 14, 2009 | KWorld PC to TV (0872880887527) Video...
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
GE 27GT271 locked onto satellite mode?
Is there a way to unlock the satellite setting? no. Will we have to sign up for satellite for a month or so, so that we can unlock it? yes I do not know about your place I stay in INDIA & here unless you subscribe you can not see cable channels. Or are we just out of luck on this?
Sep 24, 2007 | GE 27GT722 27" TV
Sanyo DS27510 27" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
