Question about Lincoln Electric K1170 AC-225 Stick Welder
I have a ranger 305g, sometimes cant get arc out of machine but the generator part still works all wires look like they are hooked up, this has happened in the past all i did was level the trailer and it went to working, ive changed the brushes
2 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
Posted on May 07, 2009
Lincoln 305g kick out breaker with just 4.5 inch grinder
Have you tried another grinder, or a heater is a good test.
Could be a weak breaker. I use a 1500 watt heater to test outlets with.
Feb 10, 2015 | Lincoln Ranger 305g Welder Generator...
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
Jun 27, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Can I run a millermatic 252 mig welder off of a ranger 305 g auxillary power outlet?
not sure what a ranger 305g is but a mig welder of that size would require an output of at least 10kva from a generator maybe more due to the start up current
Oct 27, 2013 | Welding Tools
I have a fuel prob.in a lincon 300 g starts for a couple seconds then fuel stops going into carb and dies, could it be the fuel pump?
If the unit sat for a while the jet in the carb is clogged,if this is the case the carb must be removed and dissasembled,the jet has a small orifice that can be cleanened with a paper lip or a torch cleaning wire.
Feb 26, 2011 | Lincoln Ranger 305g Welder Generator...
Engine oil leaks out the gasket between cases how will i repair
Two options here:
1) The one i will suggest... send it to an authorized repair shop. Check with your local welding shop/store (Praxair has direct connection with the anywhere), they will ship it down to an authorized dealer.
2) If you are a mechanic or know how to change head gaskets, then take model and serial number of your engine (p.e.Kohler, onan or honda) and go to a autoparts shop and ask for the gasket, then just replace it.
Feb 06, 2011 | Lincoln Ranger 305g Welder Generator...
I have a 305g machine runs gen works i do not get any read out from the displays
If it is a digital, you need top replace it. They burn pretty easy with overloads.
Dec 24, 2010 | Lincoln Ranger 305g Welder Generator...
My lincoln ranger 250 no weld output
sounds like the transformer winddings which generate the amperage for the arc are breaking down
Jul 03, 2010 | Lincoln Welding Tools
What size battery goes in a 305g?
Group 58 battery with 435 cold cranking amps. Page 3 in pdf manual.
Here is a pdf manual site for your welder...
http://content.lincolnelectric.com/pdfs/products/literature/e6117.pdf
Mar 05, 2010 | Lincoln Electric Ranger 305G K1726-4...
Lincoln Electric K1170 AC-225 Stick Welder Logo
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
