Question about Chefmate Kitchen Appliances - Others
How do you switch Chefmate digital scale from grams to ounces?
Toggle so that "weight" is blinking, then hit zero or "0". that's it.
Posted on Jul 31, 2010
Salter high precision stainless scale 1078ss. How do i get it to weigh ounces
Put the weight on the scale. It should weigh ounces, pounds, grams, and killograms, all in the same unit.
May 12, 2017 | Salter Health & Beauty
What 3 tools should I use to measure 5 grams of macaroni , 10 ml of milk and 3 cm of butter?
To measure the macaroni, you are measuring mass or weight, so you would need a scale.
To measure the milk, you are measuring volume, so you would need a measuring glass or a set of measuring spoons.
To measure the butter, you are measuring distance, so you would need a ruler.
I hope this helps.
Let me know if you have any questions.
Good luck.
Paul
Sep 08, 2015 | Home
Weight of a gram of sunflower seeds
A gram of sunflower seeds weighs exactly one gram or one-thousandth of a kilogram.
If you want the Imperial equivalent there is about 28 grams to the ounce so one gram will equal one twenty-eighth of an ounce.
Measuring such small weights requires a different measuring scale and the apothecary measures are appropriate: the dram is one sixteenth of an ounce.
For rough measure purposes one gram is about a quarter of a dram.
For exact purposes all the conversions can be found by google.
For practical purposes it would be better to measure out one ounce, one half-ounce or one quarter-ounce of seed whichever can be done most accurately and then divide it by eye into 28, 14 or 7 equal portions in order to obtain approximately one gram.
If greater accuracy a chemical balance would be required.
Feb 26, 2015 | Birds
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
Manual
You may download a copy of the manual here.
Mar 02, 2013 | Royal DS3 Exacta Electronic Postal Scale...
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
I have a set of hanson kitchen scales and i cannot change it from fl oz to grams etc
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Feb 08, 2010 | Health & Beauty
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Sep 08, 2009 | Health & Beauty
Kitchen Appliances - Others Logo
855 people viewed this question
Top Chefmate Kitchen Appliances - Others Experts
NOEL
NOEL
Ruth summersides
Are you a Chefmate Kitchen Appliances - Other Expert? Answer questions, earn points and help others
