Question about Hitachi 43UWX10B 43" Rear Projection Television
Red shadows in my hitachi
Getting red shadows. looks like almost seeing double
    Novelist:
    Champion:
  • 211 Answers
You probably have a bad convergence chip on the convergence board. I have worked on many of the same type of sets and this is normally the main cause of your problem. I suggest you seek a qualified technician to change these chips and also I suggest you ask the technician to change both ( there are 2 convergence chips in your set ), as it seems when one goes bad, the other is on it's way out also. I hope this has helped.
Happy Presidents Day
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
Seeing double- almost like a shadow or 3-d when you aren't wearing the glasses
Thats a convergence issue. You can get the repair kit for that model hitachi from www.tvrepairworld.com under the Hitachi Repair Kits page.
Mar 22, 2013 | Hitachi 51F500 51" Rear Projection...
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
My grandfather has a Hitachi 50ux58b and is having double vision or shadowing -- whatever it's called and redness color fading-like. Was told it was a convergence IC that needs replaced -- uncle looked...
try not to do repair yourself. the tv holds high voltage even when unplugged. you could KILL yourself. If red is fading the convergence ic will not help. you need to replace all the guns. red, blue, and green. usually each tube or gun is around 300 dollars each.
Mar 21, 2011 | Televison & Video
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Shadows and double vision
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2009 | Hitachi 50FX30B 50" Rear Projection...
Shadows double vision
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Apr 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Red in Color Shadow
contact authorized servicer to do a memory initialization in the service mode
Apr 02, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Our hitachi 50 inch tv has started having red and green lines in it....it is more on the left side of the screen. Also it has a smeared looked...like a shadow.......double look to it.......can this be...
Unit has bad convergence IC's and maybe open resistors. If your technically inclined you can replace the ic's yourself and look for burned resistors. I would need your model # to give you the ic locations and part #;s
Apr 07, 2008 | Televison & Video
Red double
Bad solder connects in convergence circuit...a solid fix is to
replace STK392-110 convergence IC's with upgrade STK394-160
Part # CZ 01341... you need two.....or buy kit # X480295 ( one )
Look for any damaged resistors near IC's.............T.
Dec 16, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
74 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
