Question about Garden
Cleaned carb.request settings for idle &high screws original turns.mod.walbrow 358.355141 ser.94014402185
  • 246 Answers
SOURCE: Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>There are Several Location for the Air Mixture Screws.
>>The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore).
>>If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required.
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Holding the Throttle Full Open, Start the Engine.
>>Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle.
>>Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle.
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 86 Answers
SOURCE: 2005 ktm 520 won't idle, cleaned carb new diaphram
did you try adjusting the air fuel mix screw?
Posted on May 21, 2009
panilling9
  • 284 Answers
SOURCE: What are the factory settings for the
find L on your carbruetor and turn it clockwise 1/4 turn to see what difference it makes
it should begin to idle by itself?
zama carb. 1 turn out from closed
walbro 1and 1/4 from closed settings are only preliminary
Posted on Jun 14, 2009
  • 245 Answers
SOURCE: 1986 YF 60 4-Zinger. carb settings
The air/fuel screws won't have any effect on the top end. That would be governed by the main jet. Did you install the Boyseen Reeds? If this is a new addition it could be the problem. Another thing could be the fuel level in the carburetor bowl. When you tore down the carb it is possible the float got out of adjustment. You could drop the bowl and see if the fuel level is correct. If not, bend the tab on the float to adjust it.
Posted on Oct 03, 2009
wiringlunati
  • 576 Answers
SOURCE: Toro snowblower///// tecumseh# on motor is H35-45598R SER 5283B
Usually that is a sign of the carb not being adjusted right. Run it at full throttle and adjust the main mixture needle (usually on the bottom) until it runs the smoothest. Set it in the middle of the range where it runs smooth. Then set it down to idle and adjust the idle mixture until it runs smooth at idle. Accelerate it rapidly and if it bogs or hesitates turn the idle mixture a little leaner (clockwise) and try again until it works right. That should get you very close. Try tweaking it a bit from there. as the microscopic specks clean out of it, it may need more adjusting.
Posted on Nov 25, 2009
I need initial screw settings for a YFM80 Moto 4 carburetor. I just rebuilt it but can't find initial screw settings.
Hey William,
By rebuilt, do you mean the carburetor?? ..or the engine??.. if you rebuilt the carb and you did not remove these screws ( and count the revolutions out from lightly seated), then you did not do the rebuild the carb correctly.. sorry.. What, exactly did you do to the carburetor?? Please reply on here to me..with details!!
thanks..
I cannot understand why someone that claims to have "rebuilt" a carburetor actually missed the BASCIS of carb rebuilding 090.. the air screw (the one on the angle toward the back of the carb has/is connected to the pilot jet system and the idle system, the passages that use this system must be perfectly clean for the engine to run properly.... the air screw has a spring. a spring seat and a o-ring for sealing on it.. the screw setting starts at 1 & 1/2 turns out from lightly seated.. then set the screw in the very side of the carburetor (its the one that controls the idle speed).. once you get the machine warmed up and cleaned out.. let it idle, turn the air screw in and out SLOWLY about a 1/4 turn at a time..EACH TIME ..waiting until the idle settles and then until you reach the point the machine idles as high as possible, then turn in it 1/8 of a turn.. then set the idle speed with the "side screw" to a speed you like... good luck...thanks!!
Jul 17, 2017 | ATVs
How do i set the carb on a ryobi
I haven't heard of Ryobi using a carb different to most similar machines which use a small diaphragm-type carb which uses suction impulses from the 2-stroke engine crankcase to lift fuel from the fuel tank into the carb. There is generally one screw which is a throttle stop and two screws which are fuel volume screws; one with a greater influence at low speed and idle and one with greater influence at high speed. The low speed screw does have some influence at high speed and the high speed screw does have some influence over low speed fuel mixture.
The basic settings of the screws should not be lost and if stripping and cleaning the carb each screw should before removing be carefully turned in, counting the turns, until it bottoms so after cleaning it can be returned to its former position.
The amount of adjustment from the position the manufacturer set each screw to would typically be in the order of plus or minus one-eighth of a turn and if adjustment of more than about a quarter-turn is needed it could indicate the carb needs a thorough clean.
Making an adjustment of one screw means adjustment of the other is almost inevitable. The basic requirement is for the machine to work under load efficiently at high speed and it is usually desirable the machine will be capable of idling. Obtaining both is rather a balancing act and will need some patience and time making minor adjustments of each screw and in practice some compromises must be made and if hard work at speed has been achieved it usually doesn't pay to try too hard to achieve a smooth idle.
Feb 25, 2015 | Ryobi Garden
Adjust idle
!. New spark plug
2. New or CLEAN air filter
3. CLEAN and properly set carb.
4. Air screw should be about 2 turns out AFTER lightly seating.
5. Adjust idle speed to your liking, but not too high.
6. Refinement is made with 1/4 turns of the air screw.
Jul 08, 2014 | ATVs
Once bike gets over 3000 it sticks there. (hanging idle)
Probably the vacumn slides are hanging up, Not because they are stuck, But because the idle screw is set too high to get to idle. The idle will usually hang up at 3,000 rpms. Set the idle mixtures at 1 1/4 turns out & make sure the throttle cable has play. Now back the carb idle down till it just idles about 1,100 rpms. with choke off. If the carb sync is way off, I will hang up on 1 carb when hot. You need a vacumn guage set to make sure they are balanced. To check the spark advance (which I doubt), Put a timing light on the LH plug wire & shine it at the timing marks behaind the LH cover on motor at botton covering the generator. It should be on the F marks at idle & at the unmarked line aprox 1 " over which is full advanced when reved up to 1/2 throttle. But yes a air leak at the intake manifold could cause it to rev, But will be a very erratic idle at 1,100 rpms. If the idle circuits are working correctly, You should be able to kill each cylinder with turning in the mixture screws one at a time. That checks the idle jet circuits.
Mar 26, 2014 | 1977 Yamaha XS 650 D
Car settings stihl 026 with wt 194 carb?
Hi Alan Cowart
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
1987 60 hp mariner idle & high idle great, stumbles/ stalls in gear on take off, head gasket or poor idle adjustment?
Clogged idle circuits in your carbs. Clean jets and passages.
You can try suck dirt out, therefore: Screw the idle mixture screw out ( almost totally ), give full throttle ( 1 second ) and then hold your hand against the carb air intake.
This will give maximum suction and can suck the dirt trough tje circuits.
Also, first drain the carb(s) to be shure there is no water in it...
Aug 22, 2017 | Light Boating
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
Jan 14, 2011 | Toro Blowers Rake and Vac - Electric...
On the husqvarna se266 carborater, what is the low and high screw settings or how many turns is the screws supposed to be at?
Initial setting for a Husqvarna; "H" and "L" screws at 1 turn CCW form lightly seated. Then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 22, 2010 | Garden
Nov 25, 2009 | Garden
Carb settings.
The idle mixture screw is on the front and should be 1 1/2 turns out. The high speed adjustment on the side should initially be one turn out. Sounds like you have more of a problem than just carburetor adjustments. Are you sure the fuel pump is assembled correctly?
Jun 07, 2009 | Garden
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
