Does putting objects on DVD player cause problems? Have two that no longer play after putting light TV on them.
Sir. i have victor jvc dr-mv1 and i need English Languige on this DVD please solve my problem.
Posted on Jan 30, 2010
Pioneer dv320-k = no longer region free??
You maybe able to get a region free code for your player from these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm
Feb 24, 2013 | Pioneer DV320K Multiregion DVD Player PAL
RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Aug 22, 2007 | RCA DRC-285 DVD Player
Can playstation act as dvd player or i should buy dvd player separately?
Yes, it can play DVD movies as well as Music CD'S and CD-R's music. You dont have to buy another machine. One tip thou when using it as a DVD plyr you might put it where ventilation can get to it - due to the overheating problem PS2 has. I use mine all the time, and I put a fan next to it, so I can play longer and watch movies longer. I hope this helps. Good Luck.
Jul 20, 2010 | Sony PlayStation 2 (PS2) Console
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Our dvd player no longer plays dvds. The super audio cd and multi chanel light is on and will not turn off. Every time we put a dvd in it will not play.
  1. try resetting by unplugging power of device
  2. look at the manual and see if there are any options related to audio type and multi channel modes. Try toggling to different settings if you see any related options.
Aug 26, 2009 | Sony DVP-NC80V DVD Player
No longer plays color picture
Try the settings for "pal - ntsc - cvbs" video formats, if the tv and dvd aren't set the same, then this can cause the problem(usually with distortion to picture, depending on how it's mis-matched)
Jul 05, 2009 | Coby DVD-224 DVD Player
Hp dvd player
This problem can often be caused by the DVD player software thinking it is in a region different than your discs. (DVD discs are often encoded with 'region codes' meaning a disc purchased in Asia will not work in a player expecting to see North American discs)
What can happen is the player 'forgets' where it is, and your regioned discs won't play any longer (region free discs should continue to work as will audio CDs ....)
A power surge, random cosmic ray or similar flakiness can cause a player to 'forget' what region it was designed for ....
If that is what has happened you need to 'reset' the region code.
Altho I can diagnose this, I have NO CLUE as to how to do this with a hp DVD player. Anyone out there know how to reset the region codes for this (or generically for a DVD player?)
Thanks!! //cheapz
Nov 15, 2007 | Televison & Video
Dvd player says "no disc"
Could a foreign object have been inserted into the tray? I have seen labels peel off and stick inside the mechanism, preventing it from reading the DVD. Also try unplugging it from the wall, let it sit for a few minutes (for the logic circuits to reset) then plug back in. Just turning it off does not reset the logic...
Nov 04, 2007 | Daewoo DV-6T834 DVD Player/VCR
Not playing movies
The clicking sound is the lens assy trying to move on the traverse mechanisim and the release spring is ticking. You might want to crack her open and look for any foreign objects in the laser area. You can also try to move the lens assy by hang gently sometimes they get stuck for no reason. Let us know :-)
Sep 14, 2007 | Cyberhome CH-DVD 300 DVD Player
Audiovox D1708
Look for dust, dirt or foreign object on the laser lens under where you put the disc in. Maybe blow some clean air on it.
Feb 27, 2007 | Audiovox D1708 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
