Question about Microwave Ovens
Diplay F6, humming noise, no responce - Microwave Ovens
  • larrykorey Jan 30, 2010
    any idea the cost of part or repair, approx.?
  • 10,515 Answers
F6 ( This is a Common Error for Whirlpool Ovens )means there has been a microwave relay failure. Unfortunately the control board will need to be replaced because the relay is part of the board and can't be serviced separately.
For Most Models - Tech Sheet States - Check wiring to relay 4903 for short circuits. If wiring is okay, replace control board.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
  • taran_2005
    taran_2005 Jan 30, 2010
    Thanks for your response!!
    Part depends on Model. It would be around $150 - $200. If you call a Tech for Repair, he would make a Bill of $300 - $450.
    As the cost would more be more than half of the new one, better to Switch to a New One. If you could Repair it, its Good but it would have a lot of Voltage. Even a small mistake could lead to a Shock.
    Hope i helped you.
    Thanks
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
While using the Bake Potatoe setting the code F6 came up on the display and the light went out and the machine was making a humming noise.
F6 on a Whirlpool microwave means your cook relay has shorted.
We can repair that with our $39.95 service (details here) or you can order a new control circuit board from the Pros here.
Jan 24, 2011 | Whirlpool Microwave Ovens
Microwave is humming when off display says F6
We had a power failure for 2+ hours. I went to defrost something when the power came back on. Somewhere along the line the F6 popped up. With the door closed it sounded like the machine was running.
I slapped the side too and it worked. I pulled the vent cover off to clean it and found the tech sheet stuffed in a bag inside. I found what F6 means. 'Microwave relay failure. Check wiring to relay 4903 for short circuits. If wiring is ok, replace control board' Then, of course, a whack on the side by the button panel worked
just as well. rek('_tx6');
Reference: It means the relay is stuck in the run position. Apparently if you slap the unit hard enough it will unstick the relay and allow it to work properly again. rek('_tx7');
Aug 06, 2010 | Kenmore Microwave Ovens
Panel displays F6; continues to hum. Will not re-set after unplugging..display continues to show F6.
F6 is a shorted cook relay on the control board.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 11, 2009 | Microwave Ovens
Displays F6 error code, hums when you start it and the tray circulates when you open the door
Depending upon which make and model you have, F6 is the code for either relay failure or shorted tempurature probe.
May 01, 2009 | Microwave Ovens
I replaced the light bulb, now it displays -F6- and pushing any button causes a humming noise.
I left the unit unplugged over night, plugged it back in the next day and still had the same problem.
Oct 13, 2008 | Roper Microwave Ovens
What does -F6- code stand for?
F6 means a problem in the control circuit board.
Try unplugging the microwave with the door open, then plug it back.
Try the solution that you find here, if it does not work the panel must be replaced.
Sep 10, 2008 | Kenmore 63652 Microwave Oven
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Kenmore Microwave hood combo Model # 66569689992 F6 error code?
Dec 08, 2007 | Microwave Ovens
Error code F6
Please post back with your your full model number. It will be three digits, then a dot, then about eight more digits.
Once we have that, we can figure out who made it for Kenmore, then look up the F6 code.
Happy to help.
Dec 04, 2007 | Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
