37 inch I bought a 37 in used phillips TV. It will be fine then will just black out but the power will stay on . you can turn it up change channel or menu when it does this . I want to know if it is worth fixing and dont want to get robbed. at times if we leave it n unplug it a while later it will work then do it again later. thanks for your help .
    Problem Solver:
  • 10 Answers
Sometimes you can re-adjust the gain on the flyback to get it to stay stable.Look to see if there is an adjustment on the yoke also. It's a temp fix. I can tell you now that the pic tube is going out. Let me know - edcarson
Posted on Feb 18, 2008
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
There is a picture for about 5-10 seconds then the
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get picture back.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | JVC LT-37X688 37 in. LCD HDTV
MY 60 INCH PHILLIPS 60PP9200D/37 WILL NO POWER
If the front power light does not come on check the fuse in the back of the Tv.
Jul 18, 2009 | Philips 60PP9200D Television
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Wharfedale 37 inch lcd tv
sounds like screen control is set too high
Sep 02, 2007 | Televison & Video
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
