Question about Philips DVP3962 DVD Player
The picture using the HD cable is like reverse colors
  • 630 Answers
Check that it is securely connected and, if component, you've connected the colours correctly
Posted on Jan 30, 2010
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
Oct 24, 2009 | Panasonic Televison & Video
Color fine with rca jacks but when using hdmi/component its not
There may be a number of problems that are causing your HD issues. They may exist in your TV, or in the box you use to tune your channels. Contact your cable or satellite provider and ask them to change out your box. If the condition still surfaces, then you need to have your TV checked. The component and HDMI jacks are both connected to the same electronics. This is why they are exhibiting the same problem.
Jul 15, 2009 | JVC AV-56P575 56" Rear Projection...
I can't get a picture on my screen, but the auido still works
Make sure the Coaxial cables are hooked up properly. I don't know the HD colors right off hand but the normal colors are [RED Audio][WHITE Audio] and [Yellow Video]. Hope you get it hooked up with videos and sounds soon. Make sure that if your useing regular coaxial cables, your not hooking them into HD slots and Vice Versa
Jul 07, 2009 | Microsoft Xbox 360 Console
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Is tv an HD tv
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Mar 11, 2009 | Philips Televison & Video
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
No color
The most common reason for this is when you use component cables (YpYbYr) and the red or blue cable is bad it will cause a black and white picture. Also doesn't hurt to check the color settings in the menu too.
Mar 02, 2008 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Hdtv/ direct tv service
more then likely you are using component input if you are check to make shore they are hooked up correctly red to red green to green and blue to blue if they are you might have a bad cable I have not seen a color stream board bad yet
Oct 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Only green when using HD component cables
Your hookup may be wrong, you may have things reversed in your component HU. Recheck your color code on y, pb and pr.
Mr Bob
Sep 08, 2007 | Philips 60PP9352 60" Rear Projection...
Philips DVP3962 DVD Player Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
