Question about Nintendo Wii Console
Wii immediately ejects disc, disc goes back in and then it ejects the disc completely.
    Brigadier General:
  • 3,513 Answers
You need to remove the disc drive and check for broken gears.
Probably one of the gears has shifted out of place; you need to reset the gears to fix your problem.
Thanks for contacting fixya.com
Posted on Jan 30, 2010
2 Suggested Answers
  • 19 Answers
SOURCE: Insert disc, wii console makes a sound, disc is
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
resma1
Posted on Jan 08, 2010
The Wii will not read my disc
Situation:
The Wii console will not accept game discs or the discs are ejecting immediately
What To Do:
Press the eject button on the front of the console. The console will not accept any discs if there is already a disc inserted, and it is common to forget that a disc was already inserted.
If the system still won't accept discs, or if the discs are immediately ejected, this indicates a problem with the mechanism that pulls the discs into the system and the Wii will need to be repaired. To begin the repair process, click here.
Nov 15, 2012 | Nintendo Wii Console
Disc will not eject
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
Aug 22, 2010 | Nintendo Wii Console
I put in a disk and it does not read the disk. The blue light goes out immediately after inserting then nothing
Sounds like the DVD drive inside of your Wii may have failed.
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Apr 09, 2010 | Nintendo Wii Console
Wii makes grinding noise, when disc is inserted, it immediately ejects it, accepts it back in, then ejects it onto the floor while making horrible grinding noises
There is either something inside of your Wii's DVD Drive blocking the insertion of the disc, or some of the gears inside of the DVD drive are damaged. Lots of times, one of the kids will stuff a penny, credit card, or some other foreign object inside of the Wii's disc slot. The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
Jan 15, 2010 | Nintendo Wii Console
Game will not eject
Most of the time, it happens in Nintendo Wii. If in case that the disc won't come out, turn off the Wii (with the disc inside of it), turn it back on after 1 minute and then eject the disc and the disc should come out.
If the disc remain stuck after resetting the Wii, then you need to contact the manufacturer. There could be some components that are no longer working correctly that needs to be changed.
Have a great day!
Sep 28, 2009 | Nintendo Wii Console
Disc is stuck inside goes on will not eject or
You will find a small whole in front of the disc. Quite small, say a niddle head size just take a pin approx 3 inches and poke it slowly inside. You shall feel the pushing of a soft touch feather button like on your keyboard and your CD will come out. Don't forget to push eject button before poking the pin. and kindly do rate my solution.
Jul 17, 2009 | Nintendo Wii Console
Wii Fit disk will not eject
aqwtr-101
Jun 13, 2009 | Nintendo Wii Console
Game stuck in console
Try thees steps
Turn the Wii.html#" target=_blank itxtdid="7750962">Wii off and on again after about 20 seconds. Press the eject button again. 2
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. Hold down the eject button for 5 to 10 seconds. 4Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. 5Call Wii.html#" target=_blank itxtdid="7751052">Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds Good Luck
Jan 23, 2009 | Nintendo Wii Console
Wii not ejecting disc
Unplug the power cord for an hour then plug it back in and try it.
Aug 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
