Question about Refrigerators
Refrigerator The lights inside my side by side blink then go out! Something is wrong. What is the matter?
  • Stoy Feb 22, 2008
    My side by side is one year old. I tried th pry up the brass contact like you suggested. Thanks for the tip, but when I did this, it made my numbers on the cold settings to go off, and a clicking noise to begin. Like there is a big short. As long as I keep the bulbs, (one on the top left side and the other lower, middle bulb unscrewed) no clicking noise and the numbers work. What is MY problem? Say I really appreciate any tips you might would have!!!
  • Stoy Feb 22, 2008
    to the comment by aborcass:
    This sounds possible, what do I do to check this out, how can I fix it? Thank you for helping.
    President:
  • Refrigerators Master
  • 2,651 Answers
Possible that the bulb recepticle is losing contact with bulb, real common among refrigs that have 2 bulbs back 2 back in one socket.UNPPLUG refrig and try prying up the brass contact arm on bottom of socket assy.UNPLUG first, that contact is live!!!!!!!!
Posted on Feb 22, 2008
  • Ron Coons
    Ron Coons Feb 22, 2008
    whats model and manufacture? whirlpool uses an electronic control behind rear of cabinet that powers lights, on some models anyway, ive seen refrig lights(even control indicators go blank) yet freezer lights work fine,
The tempature light is blinking on the freezer side
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
No longer making ice. On/Off button is blinking. What's wrong?
If you are talking about the light blinking inside the freezer located on the freezer wall, that means that the sensor has gone bad and needs to be replaced. The sensor consist of two parts, the one on one side where you see the light and on the other side of the freezer where the beam actually goes to. This is a real easy fix and the parts can be ordered from apdepot.com
Nov 08, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a 2003 v6 ford escape, last night suddenly the over drive light was blinking and the transmission change became rude i pull over and turn off the engine, but when i turn it on again the blinking...
i DON'T HAVE MANUAL FOR THAT PARTICULAR VEHICLE BT IT SOUNDS LIKE THE NSS (NEUTRAL SAFETY SWITCH) IS FOULED OR BAD. IT'S TYPICALLY EXPENSIVE BUT CAN USUALLY BE REMOVED AND CLEANED QUITE EASILY. IT IS USUALLY ON THE SIDE OF THE TRANSMISSION (PROBABLY DRIVERS SIDE). FOR THAT MATTER I WOULD CLEAN AND REPLACE ALL MY TRANS SENSORS
GOOD LUCK
Oct 22, 2010 | Ford Escape Cars & Trucks
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
-Drew
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Maytag PBF2253HEW temp control lights blinking
Your heading has two model #'s if your dealing with a PBF2253HEW you need a new jazz board pn W10165748 this part also controls your automatic defrost cycles if lights are flickering you should replace prior to something else going wrong
Apr 02, 2009 | Amana ARS2464B Side by Side Refrigerator
Samsung model RS2556SH, refrigerator
Refrigerator temperaure gauge keeps blinking and fridge is only cooling to 35 degrees
Mar 13, 2009 | Samsung RS2556 Side by Side Refrigerator
Frigidaire is freezing everything
Make sure the light is going off when the door is in the closed position. Find the switch that the door makes contact with when it closes. If the light is not going out the heat from the light being on could cause such a problem.
Aug 25, 2008 | Refrigerators
Reset the water filter indicater light
hold light and lock buttons until lamp blinking release and lamp turns off no it is reset.
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
