Question about Black & Decker 400 Watt Electromate With Radio #PS400JRB
My Black and Decker Electromate 400 will not inflate my tire,it comes on but no air is coming out of the hose.How do i take it apart to see if the hose has come off from the inside.I have taken the 4 screws out and taken the rubber bumpers off,but i cant get it apart and i don't want to force it. Is there a certain way to get it apart?
How do I download an owners manual for my Black and Decker Electromate 400?
This link just might work for you: http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90556511,VEC026BD.pdf
Oct 19, 2014 | VEC026BD Electromate 400 Jump-Starter with...
Describe in detail how to open up a electro mate 400 B&D
  1. Unsnap the black plastic tray on the bottom. Turn the unit face down. Loosen four screws along the bottom edge.
  2. Loosen two screws in the handle and one screw on each side.
  3. Use flat blade screwdriver to pry up black rubber bumper near the top (back side only) and loosen one screw underneath on each side.
  4. Open the flat panel, remove any contents and loosen two screws at the back.
  5. With all 12 screws loosened turn unit face up with bottom toward you and gently pry bottom apart. There are wires and tubes connected inside so just prop it open enough to work.
  6. Replace battery ($29 + shipping on Amazon, search on battery model like CB19-12 or EXP1218).
  7. Reassemble.
  8. Tell spouse you just saved $150; collect reward.
Sep 17, 2013 | Black & Decker 400 Watt Electromate With...
Manual for black and decker electromate 400 What do lights two red and one blinking green indicate?
I went to the Black & Decker site and downloaded the pdf manual of the electromate 400. It says you're supposed to charge it until you have one red light, one yellow light, and one green light. I expect that 2 red lights and a green light means it's not fully charged. The manual also said you can't overcharge using the 120 V. method. Good luck.
Feb 05, 2010 | Black & Decker 400 Watt Electromate With...
How do i dissasemble my Black and Decker Electromate 400
Cold weather can freeze the water that the compressor normally makes, try warming up the unit first.... eliminate the simple problems first.....
Jan 30, 2010 | Black & Decker Air Tools & Compressors
HOW CAN I TELL WHEN IT IS FULLY CHARGED?
What are you talking about? You don't mention the electrical item.
May 23, 2009 | Black & Decker 400 Watt Electromate With...
No AC power
Why does the AC indicator light constantly flash and I have no AC power on my Black and Decker Electormate 400
May 03, 2009 | Black & Decker 400 Watt Electromate With...
I need clamp for Black & Decker Electromate 400 Portable Jump Starter
I work for Black and Decker customer support. Our customer service phone number is 1-800-544-6986.
Please call the number above so that we can assist you with your part request.
While this doesn't actually solve your problem, I hope the information allows you to make an informed decision as to how to proceed from here. Please let me know if I can be of further assistance.
Apr 15, 2008 | Black & Decker (050876530606)
Black & Decker 400 Watt Electromate With Radio #PS400JRB Logo
109 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
