Question about Motorola Computers & Internet
I want to get to my modem setting - Motorola Computers & Internet
    Novelist:
  • 157 Answers
Your modem ip address is any of :
192.168.1.254
192.168.1.253
192.168.254.254
The login and password if not changed by you is admin/admin.
If none of these work you need to call your service provider tech department and ask them for it. They may choose to not give it to you and in that case you are out of luck.
Posted on Jan 30, 2010
Cant set security
According to you security settings of your modem is difficult for you.
But you don't have say the OS you are using there. It depend on modem and OS. while installing the driver supported your OS select the PPPoa/PPPoE. After installing go to the web explorer and type the link (IP add) of your modem at the address bar and enter in the modem settings. Your modem vendor will provide this IP or see the manual.
Then go to the security settings and set it pasword protected. Enable the NAT (Network Address Translation)with your Private IP address for security. You can follow the manual to set it properly
Mar 24, 2011 | Zyxel Prestige 630-C DSL Modem...
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
Nov 05, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
D-Link modem is dead.
Try to configure the settings of the d-link modem. Make sure the atm circuit identifier goes along with the settings required by yopour isp. If not, try to check it with them. Normally, internet connections make use of vpi as 8 and vci at 35 for ciruit identifier. Try that. You can change the settings of the modem by pulling its interface.
Hope that helps.
Jun 24, 2009 | D-Link DSL-2320B
Ethernet cable port does not worked only the usb port worked
Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Dialup link problem
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 02, 2008 | Paradyne COMSPHERE 3910 Modem
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Mtu
The modem (westell wirespeed)you have does not have is a old modem... that does have options to set the mtu settings. You need to change the modem. By the way why you need to set the MTU settings,.
Apr 07, 2007 | Westell Wirespeed LiteLine 6110 Modem
Computers & Internet Logo
159 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
