Question about Kenmore Washing Machines
Water leak at drum seal bearing? - Kenmore Washing Machines
  • 129 Answers
YES
Posted on Jan 31, 2010
Washer drum making loud noise when spinning
Reach into the drum (on a front-loader)and push upward to see if it moves at all, you should feel no play where the drum support shaft passes through the bearings... The bearings will "roar" loudly during spin if the main seal has leaked water into them... Top-load washers will exhibit the same roaring if the seal fails in them also. Whirlpool Tub Seal and Bearing Kit W10435302
May 13, 2016 | Washing Machines
Is repair time and parts extensive for this type of repair? Kenmore Front Load Model# 110.45986401
Confirm that it is not the door seal. The door seal can easily be replaced and the parts are available.
You would expect that any water leaking around the door seal would migrate down to the lowest part of the tub leaving the appearance that the leak is where the two half's of the tub are joined by the retaining clips
Replacing the seal between the two tub half's is a different story as compared to the door seal. The tub seal is definitely do-able, but not for the faint of heart!!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
If the leak is very very small I might wait until a major overall is require such as the tub seal/bearing. If I chose to wait I would monitor the situation.
Inspect the area at the hub of the pulley looking for streaks of rust.. If there is an indication that water is leaking past the basket tub seal than doing an over hall now may included front door seal, tub seal, bearing and basket seal replacement.
Dec 30, 2015 | Washing Machines
Speed queen awm270w3062
i think the drums bearing seal is shot
you need to replace the seal and the bearings
or.. you need to check the drain hoze pump and water recycle systems for leaks
try to fill it a little manualy and see if it leaks
use a bit of newspaper to see whats going on under it
otherwise its a de hoze it take it out and lay it down look see where its coming from
May 16, 2014 | Speed Washing Machines
Hotpoint WMA30 is leaking a small amount of oily water from the back of the drum when in use. There is a small hole in the back of the drum, should there be a screw in this hole that has fallen out?
Thwater is leaking because the shaft seal has worn, and the hole is supposed to be there as it is a drainage hole.
The outcome will be that the main drum bearings will eventually fail as the water will get into the drum bearings.
To replace the seal involves a complete strip down of washer. not a job to be undertaken by yourself, unless you know what you are doing.
Nov 14, 2010 | Hotpoint WMA30 Front Load Washer
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
IT LEAKS WATER AND IT MAKES A REAL LOUD NOISE WHEN IT'S SPINNING..
your drum bearings and tub lip seal are defective,it requires you to remove the rear access panel and the inner drum,then remove bad seal and bearings
Mar 09, 2010 | Washing Machines
Amana washer model# nav4800aww leaks water on the floor while washing large loads. Now it does it on all loads.
firstly remove rear cover and check during running if any hose is leak?
or-
water seal inside drum is leak for this drum has to be open. mostly bearing are damager due to water entering bearings. so bearing are needs replacement.
Nov 05, 2009 | Amana Washing Machines
Maytag Washer noisy & leaks lots of water from bottom of machine
the drum bearing are damaged due to water leak from seal inside the drum. that's why water on the floor. silicone paste mo use as it has other major problem.
Nov 02, 2009 | Maytag Washing Machines
WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Sep 22, 2009 | Washing Machines
Water leaking between drum and top of gear box.....Washer is an Amanda NAV5800aww
center seal leaking ..repair not for faint of heart if you hire it done be sure they change upper bearing ..water is leaking onto bearing and failure can occur in less than 2 weeks after seal replacement
Oct 03, 2008 | Amana Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
