Question about Electrical Supplies
I have a craftsman model 315 circular saw i have to change power cord where do i put ground wire since it is a 2 prong cord? i have 14-2 gw to replace it with.
    Guru:
  • 1,051 Answers
If the cord needs replacing because of a defect return it to Sears. Craftman tools are gauranteed virtually forever. I return a circular saw a few years ago agter useing it fo over 5 years and they replaced it, no questions asked.
Posted on Jan 30, 2010
My circular saw is not working
Check brushes...
Dewalt Craftsman 2 Pack Carbon Brush Holder for Saws 147097 09 2pk
or sometimes the switch fails...
Craftsman 7621301 Circular Saw Switch
if you luck out, it may just be a broken wire, right at the switch, or right where it enters the saw? Pulling the, or directly on the cord vs. just the plug puts a lot of strain on the wires.
But if it is one of the parts above, very easy repair.
Apr 13, 2015 | Craftsman 7 1/4" 12 Amp Skill Saw
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My craftsman circular saw stopped working is there some switch safety issue
There are three possibilities, listed below in order of probability.
1. Bad power cord or broken plug
2. Dirty or burned-out switch contacts
3. Bad motor brushes or other broken internal connection
First, inspect the power cord, especially at the plug. If the blades on the plug are heavily tarnished, polish them to ensure a good connection. If you are in the habit of disconnecting by yanking on the cord instead of pulling on the plug to remove it from the outlet, the problem is very likely a broken wire right at the plug. Have a helper hold the saw with the trigger on while you manipulate the cord at the plug. If the saw starts at all, you'll need to replace the plug.
If this doesn't work, the fault is at the saw itself. Unplug the saw and remove the cover (you will probably have to remove the blade to get at some of the screws). Use the resistance range on a multimeter to check for continuity across the switch while it is on. If the resistance is more than a couple of tenths of an ohm higher than that of the test leads connected directly together, the switch contacts are not in good condition. Check for continuity between the hot terminal of the switch and the hot prong on the plug, and between the neutral (white) wire to the motor and the neutral prong on the plug. Also, if you have a three-wire cord, check for continuity of the ground (green) wire from the case of the saw to the ground pin on the plug (the saw will work with this open, but you lose the safety protection of the ground wire if it is open).
If all of these check out, then you'll need to check the motor. First, look for a resettable breaker or thermal protector on the motor. This will be a short plastic rod or button (red, black or white color) on the brush end of the motor, if present. Push it in - if it clicks on the way in, it was tripped. Next, do a resistance check on the motor. You should have a low resistance from the switch to the neutral wire (i. e., through the motor). If it is much more than a few ohms, remove the brushes and clean the commutator with a cotton swab soaked in isopropyl alcohol. Inspect the brushes - if they are broken or severely worn, replace them. Recheck the motor continuity after you put the brushes back in. If your first continuity check showed an open circuit and it still reads open, you may have a tripped or blow thermal protector in the motor (some internal thermal protectors are buried in the winding and can only be replaced by having the motor rewound).
Carefully check all electric connections before reassembling, and make sure no wires are pinched by case parts or the switch mechanism. Reassemble the saw completely before applying power.
Apr 10, 2014 | managemylife.com
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
Need a power cord for a porter-cable circular saw model 146
All of Porter-Cable's circular saws have model numbers starting with a 3. Assuming your saw is a 346, Porter-Cable's part number for that cord is 330079-98. If your model number isn't 346 or you can't get that part number, most any nine to twelve foot 14-2 power cord will work on your saw.
Feb 24, 2013 | Porter Cable Saws
Craftsman Miter Saw stopped working
Are you plugged into a GFI receptacle? If so maybe you have to reset the GFI. I would also check for loose wires on the switch or plug and make sure your cord is good.
Aug 20, 2012 | Craftsman Saws
Can the cord on a Circular Saw be replaced? By whom?
you can replace it your self . you can cut cord shorter and put on a new plug. @ home depot you can replacement parts
Nov 15, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
Jul 31, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
10'' Sears MITER saw cord nick cut 1/3 way through 1 copper wire.
as long as the wires are intact it is still double grounded and yes you can replace the cord, as to not working sounds like a wire is broken
Mar 15, 2009 | Saws
Electrical Supplies Logo
183 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
