Question about Carrier XHD183D Air Conditioner
I have a carrier wall heater with a remote, and I don't have the directions for the remote. I can't turn the heater on! I press the power symbol, but nothing happens.
    President:
  • 1,515 Answers
Hi, Sally378, I may need to get any model numbers you may have for the remote or the unit to solve this. If this remote has batteries you may want to change them to see if this takes care of it. If not, send me the model numbers from both the remote and unit itself.
Sincerely,
Shastalaker7
Posted on Jan 30, 2010
The heater is not displayed on the wall remote.
The modern Life., You'll need some how to track it down. However, are the batteries in the remote Fresh? I mean to ask, how old are they? And, are the sensor lenses clear of whatever?
May 02, 2014 | Heating & Cooling
Key symbol appears on digital display and heater will not start. Model: rinnai avenger 25 plus
The Key Symbol means the controls have been locked. Either by accident or intentionally. If you don't have the code to unlock the controls. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 30 minutes and plug the unit back in, turn the Master ON/OFF Switch to ON. The heater should have reverted back to the original factory settings. Now, you can change the settings to whatever you prefer. Just stay away from the Lock-Out button.
Hop this helped you solve the problem. Please let me know. Thanks.
May 25, 2011 | Rinnai Heating & Cooling
The problem using the lg 6711a is that i dont know that how to use its heater. Its an a/c+heating system, the remote just shows some symbols. please tell me that how can i use its heating system/how to...
Press on/off switch and then press mode button still cool symbol * and then set your temp 23 by pressing < or > And for heat press mode still symbol heat (symbol like sun), and set temp 29.
To switch off again press on/off button. Is it helpful?
Dec 17, 2010 | Heating & Cooling
We're renting an apartment in Cairo, Egypt, in which there's a Carrier air conditioner/heater Model 282601 with a remote control. No instructions. We would like to know how to use it properly. At the...
Power on first. Then, in remote, press on/off button. Press mode button still cool or heat symbol displayed (whichever mode you want). If cool, set 23 degree and if u need heat set 30.And wait for 3 minutes to function compressor.
Dec 16, 2010 | Heating & Cooling
What is error #1200 mean.
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Oct 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Need the model no. It will be on the unit somewhere, on a plate on the back area, or if it's a unit with seperate condenser, the no will be on the condenser outside, or wherever it is.
Dec 30, 2007 | Heating & Cooling
Carrier XHD183D Air Conditioner Logo
153 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
