Question about SanDisk Sansa m240 MP3 Player
Frozen, will not do anything
Goes directly to sansa screen and will not play or respond. Will not connect to computer and computer is not recognizing it. Have removed the battery and tried to reset. Nothing works. Fairly new and hardly used.
  • 1 more comment
  • fintucky Feb 18, 2008
    Not showing it anywhere... now what?
  • fintucky Feb 19, 2008
    sorry, not showing it listed anywhere. Tried turning the device on and off, but it is still not listed. I will try to find the disk that came with it. Thanks for trying.
  • fintucky Mar 03, 2008
    Per san disk, it is trash. They will not stand behind their products and offer a replacement or have the pink M240's recalled. I will NEVER by another san disk product again.
    Sergeant:
    Champion:
  • 310 Answers
Connect this with your computer and go to control panel -> add hardware ->. In that read it and select every one and click next, it detect your sankdisk. After this method your sankdisk is not detected means contact me..
Posted on Feb 18, 2008
  • khader ibrahim Feb 18, 2008
    Do these steps:
    1) connect with the system.
    2) go to start -> control panel will their in that select add hardware.
    3) a new dialog box will appear in that read it and select give next it find your device and it show its work properly or not.
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Jul 18, 2011 | SanDisk Sansa Clip MP3 Player
I think mine is the e260 - 2 gig sansa. The last time I turned it on, it resumed playing the album that had been playing the previous time I used it - as normal. When the album finished and I tried to...
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 09, 2010 | SanDisk Sansa e250 MP3 Player
Sansa Fuze MP3
Disconnect the player, press and hold the power button till the player resets. Change the USB mode to MTP, then turn the player off and reconnect to computer. The computer should now recognize the player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 05, 2009 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
press the + for a couple sec then it a wizurd should pop that should work
Sep 27, 2008 | SanDisk Sansa MP3 Player
Help with my 2 sansa c150 frozen!
all you have to do is let them run out of battery
May 16, 2008 | SanDisk Sansa c150 MP3 Player
Sansa wont work
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
Sansa m250 is frozen on initializing screen
my e200 does that im sooo pissed it just stays on the screen turns blue than goes back to home screen. i let the batteries run out and the same thing still happens!!
Nov 21, 2007 | Audio Players & Recorders
My computer doesnt recognize my sansa
their are over 11000 problems with this sansa 4GB player. IT is strongly recommended not to buy this ...My screen frozen, computer undection USB, songs deleted by itself, something error.and ETCCCCCCCC>.. latino, ur right, try reseetinn it , then unistall drive..might fix the problem..good luk ..
Oct 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
