Question about Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel
Door sealing gasket
I have a 1947 Crosley Shelvador that is still running, but the door gasket is very dry and not sealing well.  Is it possible to get a replacement?
2 Suggested Answers
  • 1073 Answers
SOURCE: refrigerant pressures
normal 3 lbs on low side
Posted on May 28, 2008
Can gasket for CR09FFW be replaced?
if you are referring to the door seal ( sometimes called a gasket) yes it can be replaced by a new genuine item or in some areas there is a private operation that goes around making door seals to fit and are fitted as part of the price
look in the yellow pages (business directory ) for refrigerator repairs or refrigerator door seals
Note here - although you may contemplate doing the job your self , some old seals are glued in and need knowledge as how to remove it , and the door will some times go out of shape when the door shelves panel is removed so it is best to get in a professional to do the job
Nov 11, 2015 | Crosley Refrigerators
How much is a door handle for a Crosley Shelvador 1952 model?
The only place I have ever seen that refrig is on the TV show "American Restorations" The are located in Las Vegas. Worth a try.
Dec 09, 2014 | Westinghouse Refrigerators
How muc`h is a door handle for a Crosley Shelvador 1952 model?
The one shown in the link below is $20.90. However, you will need your exact model number to be sure it's the right one.
Crosley Refrigerator Handle 218428101
Dec 09, 2014 | Crosley Refrigerators
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
Crosley side by side freezer and fridge have ice in bottom
Hello - A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Another possibility is an air leak and the cool air is causing the frost buildup. I suggest contacting a professional to move forward accurately and have them check the coolant system.
Dec 04, 2012 | Crosley Refrigerators
Defrosted a Crosley freezer, have water draining from door
ITS RARE BUT NOT UNUSUAL,its only condensate from the surrounding room collecting inside a cold door frame,if you dont defrost it at least twice a year,you will loose efficiency.
Jul 05, 2010 | Freezers
Crosley fridge will not stop running?
Check the seal (gasket) around the door. If the seal is not sealing properly the compressor has to keep running all the time.
Aug 07, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel Logo
100 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
